Passing traffic across interfaces with same security levels.
ddevecka
I am trying to pass traffic across 2 interfaces with the same security levels and I can't seem to get it to work past the Firewall its self. I can ping across the firewall to the other network, but I can't get this to function from a network PC. I am running and ASA 5505, and I have enter the same-security commands as well.
17 Replies 17
Yes , with this command , you can communicate with with the networks on the two interfaces. It will only not work for the far end interface on the ASA device.
Thanks and Regards,
Vibhor Amrodia
As i pointed out earlier , if you are trying to ping the far end interface , it would never work on the ASA devices.
You have to ping another device in that far end network.
Thanks and Regards,
Vibhor Amrodia
This will never work on the ASA device and is expected.
Thanks and Regards,
Vibhor Amrodia
