PBR not Routing on FTD (with FDM)
kmcgraw
We have two internet providers. Trying to route all outbound Internet traffic to the second ISP but PBR is not working after applying the configuration on FP1140.
After enabling the route map the device matches to the correct next ip hop as configured but it ignores the setting and uses the default route on E1/1(outside) and not E1/4(outside-ISP2).
I have configured an additional NAT for traffic heading to ISP2.
I don't know what what I am missing.
Here is the config:
access-list PBR_ACL line 1 extended deny ip 172.16.5.0 255.255.255.0 10.0.0.0 255.0.0.0 log disable
access-list PBR_ACL line 2 extended deny ip 172.16.5.0 255.255.255.0 172.16.0.0 255.240.0.0 log disable
access-list PBR_ACL line 3 extended deny ip 172.16.5.0 255.255.255.0 192.168.0.0 255.255.0.0 log disable
access-list PBR_ACL line 4 extended permit ip 172.16.5.0 255.255.255.0 any4 log disable
route-map RouteMap_PBR, permit, sequence 10
  Match clauses:
    ip address (access-lists): PBR_ACL
  Set clauses:
    ip next-hop xxx.xxx.81.49
    community none
interface Ethernet1/1
nameif outside
cts manual
propagate sgt preserve-untag
policy static sgt disabled trusted
security-level 0
ip address 10.33.3.31 255.255.255.0
interface Ethernet1/2
nameif inside
cts manual
security-level 0
ip address 172.16.2.10 255.255.255.0
policy-route route-map RouteMap_PBR
interface Ethernet1/3
nameif dmz
security-level 0
ip address 192.168.0.1 255.255.255.0
interface Ethernet1/3.1
vlan 50
nameif extranet
security-level 0
ip address 172.16.1.1 255.255.255.0
interface Ethernet1/4
nameif outside-ISP2
security-level 0
ip address xxx.xxx.81.50 255.255.255.240
Packet Tracer results:
Phase: 1
Type: PBR-LOOKUP
Subtype: policy-route
Result: ALLOW
Elapsed time: 48640 ns
Config:
route-map RouteMap_PBR permit 10
 match ip address PBR_ACL
 set ip next-hop xxx.xxx.81.49
 set community noneAdditional Information:
 Matched route-map RouteMap_PBR, sequence 10, permit
Phase: 2
Type: INPUT-ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Elapsed time: 3584 ns
Config:
Found next-hop 10.33.3.1 using egress ifc  outside(vrfid:0)
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Elapsed time: 6144 ns
Config:
access-group NGFW_ONBOX_ACL global
access-list NGFW_ONBOX_ACL advanced permit object-group |acSvcg-268435519 ifc inside any ifc outside any rule-id 268435519 event-log both
access-list NGFW_ONBOX_ACL remark rule-id 268435519: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 268435519: L5 RULE: Allow ICMP Out
object-group service |acSvcg-268435519
 service-object icmp
 This packet will be sent to snort for additional processing where a verdict will be reached
 Forward Flow based lookup yields rule:
 in  id=0x14c189e11c10, priority=12, domain=permit, deny=false
    hits=8437, user_data=0x14c1a4c36080, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
    src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0, tag=any, ifc object-group id 13688
    dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, tag=any, ifc object-group id 19353, vlan=0,
    src nsg_id=none, dst nsg_id=none
    dscp=0x0, input_ifc=any, output_ifc=any
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside,outside) after-auto source dynamic Inside_Network |10.33.3.251 interface
Dynamic translate 172.16.5.82/0 to 10.33.3.251/11427
 in  id=0x14c18c7a09a0, priority=6, domain=nat, deny=false
    hits=273834, user_data=0x14c18c7a8b40, cs_id=0x0, flags=0x0, protocol=0
    src ip/id=172.16.0.0, mask=255.240.0.0, port=0, tag=any
    dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any
    dscp=0x0, input_ifc=inside(vrfid:0), output_ifc=outside(vrfid:0)
Phase: 5
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
 in  id=0x14c1b9f85430, priority=0, domain=nat-per-session, deny=true
    hits=684919, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
    src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any
    dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any,
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x14c1bfb2d080, priority=0, domain=inspect-ip-options, deny=true
    hits=330898, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
    dscp=0x0, input_ifc=inside(vrfid:0), output_ifc=any
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Elapsed time: 19968 ns
Config:
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect icmp
service-policy global_policy global
 in  id=0x14c1bdc568b0, priority=70, domain=inspect-icmp, deny=false
    hits=8590, user_data=0x14c1bdb6cbf0, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 in  id=0x14c1bdc6b410, priority=70, domain=inspect-icmp-error, deny=false
    hits=8590, user_data=0x14c1bdb6faf0, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 9
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Elapsed time: 1024 ns
Config:
 in  id=0x14c18cebf3f0, priority=13, domain=ipsec-tunnel-flow, deny=true
    hits=313386, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
 out id=0x14c18c1dd010, priority=6, domain=nat-reverse, deny=false
    hits=311130, user_data=0x14c18c7b9060, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 11
Type: NAT
Result: ALLOW
Elapsed time: 34304 ns
Config:
 Reverse Flow based lookup yields rule:
    hits=684921, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Elapsed time: 512 ns
Config:
 in  id=0x14c1be169540, priority=0, domain=inspect-ip-options, deny=true
    hits=318483, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
    dscp=0x0, input_ifc=outside(vrfid:0), output_ifc=any
Phase: 13
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Elapsed time: 14336 ns
Config:
New flow created with id 898972, packet dispatched to next module
Module information for forward flow ...
snp_fp_inspect_ip_options
snp_fp_snort
snp_fp_inspect_icmp
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Module information for reverse flow ...
snp_fp_translate
snp_fp_inspect_icmp
snp_fp_snort
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Phase: 14
Type: EXTERNAL-INSPECT
Subtype:
Result: ALLOW
Elapsed time: 28160 ns
Config:
Application: 'SNORT Inspect'
Phase: 15
Type: SNORT
Subtype: firewall
Result: ALLOW
Elapsed time: 169260 ns
Config:
Network 0, Inspection 0, Detection 0, Rule ID 268435519
Starting rule matching, zone 1 -> 2, geo 0 -> 0, vlan 0, src sgt: 0, src sgt type: unknown, dst sgt: 0, dst sgt type: unknown, user 9999997, no url or hos
t, no xff
Matched rule ids 268435519 - Allow
Phase: 16
Type: SNORT
Subtype: appid
Result: ALLOW
Elapsed time: 13740 ns
Config:
service: ICMP(3501), client: (0), payload: (0), misc: (0)
Phase: 17
Type: INPUT-ROUTE-LOOKUP-FROM-OUTPUT-ROUTE-LOOKUP
Subtype: Resolve Preferred Egress interface
Result: ALLOW
Elapsed time: 9728 ns
Config:
Phase: 18
Type: ADJACENCY-LOOKUP
Subtype: Resolve Nexthop IP address to MAC
Result: ALLOW
Elapsed time: 2560 ns
Config:
Found adjacency entry for Next-hop 10.33.3.1 on interface  outside
Adjacency :Active
MAC address a44c.11e5.b500 hits 3133786 reference 5904
Result:
input-interface: inside(vrfid:0)
input-status: up
input-line-status: up
output-interface: outside(vrfid:0)
output-status: up
output-line-status: up
Action: allow
Time Taken: 380120 ns
7 Replies 7
It looks like your PBR matches traffic correctly, but the packets still use the default route instead of being forwarded to ISP2.
You can check NAT/
# nat (inside,outside-ISP2) after-auto source dynamic Inside_Network interface
Joshqun Ismayilov
Yes I have got that.  I don't get why it is ignoring the PBR.
Manual NAT Policies (Section 3)
1 (inside) to (outside) source dynamic Inside_Network |10.33.3.251 interface
translate_hits = 521520, untranslate_hits = 8927
2 (inside) to (outside-isp2) source dynamic Inside_Network |xxx.xxx.81.62
translate_hits = 0, untranslate_hits = 0
It looks like your PBR is not working /
Verify that the Access List used in PBR is correctly matching the traffic you expect to go via ISP2.
Would you like to share your route-map and ACL configuration?
Joshqun Ismayilov
Show asp table classify domain pbr
Show policy-route
Show route-map
Debug policy-route
Share output of above
MHM
Using the CLI console:
  This command is not supported.
Show policy-route
Interface Route map
Ethernet1/2 RouteMap_PBR
Show route-map
Match clauses:
Set clauses:
community none
Debug policy-route
Thanks for your help.
Show asp table classify ? <<- check what option you will get
MHM
kmcgraw
I figured it out.  Typo in next Hop IP address.
