ping problem in asa
fb_webuser
Level 11
Level 11
i want to ask about asa 5510
i connect the asa with two pc ( one act as inside and the other act outside ) and i configure the asa
put the problem is .. i cant ping the inside pc from outside and vise versa
i tride many thing that i read in cisco website like
1) enable icmp using acl
2) using policy-map global_policy
but no thing is change
can any one help me please
thank u
Posted by WebUser Sumaya Kraishan from Cisco Support Community App
Julio Carvajal
Paste configuration and PC addresses
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
fb_webuser
Level 11
Level 11
this is the running config
ASA Version 8.0(2)
hostname ciscoasa
enable password u2AaIZCt5OzuUZet encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 100.100.100.1 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/4
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list LIST1 extended permit ip any any
access-list LIST2 extended permit ip any any
access-list internal extended permit ip any any
access-list internal extended permit icmp any any
access-list external extended permit icmp any any
access-list external extended permit ip any any
access-list internal1 extended permit ip any any
access-list internal1 extended permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 int
erface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 100.100.100.0 192.168.10.0 netmask 255.255.255.0
access-group internal1 in interface outside
access-group external in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
inspect icmp error
service-policy global_policy global
prompt hostname context
Cryptochecksum:00000000000000000000000000000000
: end
ciscoasa(config)#
the pc address is
pc connected withe outside interface 100.100.100.5
pc2 connected with inside interface 192.168.10.5
Add the following commands:
global (outside) 1 interface
static (inside,outside) 100.100.100.x 192.168.10.5 where the X is an available Ip address on that range
Give it a try and keep me posted
Julio Carvajal
