PIX 506E PROBLEM
godzilla0
Level 4
Level 4
I'm at job configuring a Cisco PIX 506E, and I have a problem.
The outside interface can't reach the router wich bring the local net to the internet. I don't want anything by now but to reach the internet and do some port forwarding for some local servers. I don't care about any other aspect of the PIX as a firewall because it's a spare and we want it only to replace an old router. Then we want to do IPSEC tunneling but that's another history. By now I only want the PIX to do the same function as the old router. It could be interesting to erase everything and start from scratch . . . this is my configuration data on the old router:
ROUTER IP ADDRESS: 192.169.7.100 netmask 255.255.255.0 ( 192.169.7.0 is the local subnet )
INTERNET IP ADDRESS: 213.x.x.202 netmask 255.0.0.0
GATEWAY: 213.x.178.29
Ok. This is my actual PIX configuration:
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name work.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol http 80-88
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list ping-acl remark allow pings on the outside
access-list ping-acl permit icmp any any
access-list inbound permit icmp any any
access-list inbound permit tcp any any eq www
access-list permit_icmp permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 213.x.x.202 255.0.0.0
ip address inside 192.169.7.100 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.169.7.0 255.255.255.0 0 0
access-group permit_icmp in interface outside
conduit permit tcp host 0.0.0.0 eq 81 host 192.169.7.2
route outside 0.0.0.0 0.0.0.0 213.229.178.29 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh 192.169.1.0 255.255.255.0 inside
ssh 192.169.7.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxx
So I can reach the PIX but I can't get out of it to the inet. I don't know why, If you can answer this one, then it would be interesting to know how to make 1 port forwarding from the inet to an specific server of the local subnet on port, for example 8080. Thank you so much.
38 Replies 38
Yes, it's done now. I edited last post to include that. Ok. Now, can I erase all the DHCP stuff that comes by default ? I don't need it. As all the servers on this subnet are using static ip addressing.
Good... yes you can erase the DHCP, do (in config mode)
clear dhcpd
save with - wr m
And then we can carry on....
Ok now that's done. First warning.
I did: ip address inside 192.169.7.100 255.255.255.0, no problem.
But then I did ip address outside 213.27.252.202 255.0.0.0
And the following warning appear:
WARNING: unable to add route to OSPF RIB.
Is that the correct MASK for that IP? It should be in the form...
213.27.252.202 255.255.255.x
So my next question is.. how many public IP addresses has been assigned to you by your ISP?
Yes that's the correct mask. Now we must get the servers to reach the inet.
Ok now we are going the good way. I can ping the ISP router and the google's IP. But if I ping to the google IP from any of the servers on the local subnet I can't reach anything.
The successful ping are executed from the router's CLI. Thanks !
Good to hear it's going the correct way, ok now add the following into your PIX configuration (in config mode)... (I have named this ACL outside-in)
access-list outside-in permit icmp any any echo-reply
access-list outside-in icmp any any unreachable
access-list outside-in icmp any any time-exceeded
access-group outside-in in interface outside
Save with: wr m and try pinging IP 4.2.2.2 from one of the LAN servers, I presume your LAN servers have a default gateway of the PIX?
Let's see . . I can input the first line of your acl configuration but none of the rest.
The CLI dump the command syntax after I try to input them.
Thanks !
Now that's strange... I have the same setup on my lab PIX with no problem.
If you take out what you have already setup i.e. in config mode issue..
clear access-list outside-in
and save with wr m
After the above, copy the config that I have posted onto notepad and then copy back to the PIX in config mode i.e. all of the config in one go rather than line by line.
Doing it like you said, I was able to put this two lines, pasting on a linux console :
access-list outside-in permit icmp any any echo-reply AND
Now I can access the inet from only 1 host, the host where I'm working. It's a laptop. The rest of the servers can't ping out yet. But we are close. . . .
Sorry, with those 2 lines now all of they are getting out. Now . . I don't know if the other 2 access-list rules are necessary. I think the only thing I need now is to do the port forwarding. But I'm interested in to know how those 2 access-list rules are working, I want to understand it and if possible, could you point me to a good piece of info about the PIX 506E ? I want to take advantage of all features it can give me.
Waiting for answer, thanks.
Hello Xavier,
Are you saying that all your servers are getting to the internet?
I am happy to hear that you want to learn more about the PIX and its configurations etc, of course you can obtain the nesessary information by either purchasing or reading material from (I would recommend a book by David Hucaby) here...
http://www.ciscopress.com/bookstore/product.asp?isbn=158705485X
Or you can look up lots of configuration details from Cisco TechNotes here...
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/prod_configuration_examples_list.html
Jay
Yes, all the servers are getting out. But now I need the final touch. I need to do some port forwarding. I need, for example, that all the port 8080 from outside go to an specific host.
Then I do:
static (inside,outside) tcp [public IP] 8080 [private IP] 8080
But It does not work. Is there something more I must add to get the port forwarding working ?
Are you using the interface IP or a separate public IP? Also do you have the port open in your ACL?
I'm using the outside interface ip, It's my public IP also. Sorry but I don't know how to include the ports on to the ACL. I give you five stars for your support !
