PIX 515 Help
harrisgirls
I've just got my hands on a Cisco PIX 515.
I mainly brought it too learn and play with, i done some cisco stuff in the past but not much.
I just need too get this up and running with a IP Address on ethernet1 (192.168.1.254) but when I run the command "nameif ethernet1 inside security100" in enable mode all I keep getting is ERROR % Invaild input detected at '' maker.
Any help would be great!
61 Replies 61
just checking, I can ping DNS IP Addresses from the pix also.
if your internal PCs have the right IP, default gateway and DNS they should be able to navigate.
PC is set as:
IP: 192.168.1.166
SN: 255.255.255.0
GW: 192.168.1.250 (PIX)
DNS: 192.168.1.250
DNS2: 192.168.1.101
Let me go test again
not sure if the DNS will work like that. I have never used the PIX as a DNS server. You can use 4.2.2.2 or 8.8.8.8 as your DNS servers.
Success!!
looks like its working mate!
All I need too know now is how too port forward, for example:
SMTP too 192.168.1.101 (exchange server)
do you know what command that would be, i have a few more port forwards but im sure I can work out the rest.
you can use the following:
static (inside,outside) tcp interface smtp 192.168.1.101 smtp
access-l outside_in permit tcp any interface outside eq smtp
access-g outside_in interface outside
That should do it. Replicate the same port other TCP ports.
I things are all clear please remember to rate the thread.
Thanks, the first 2 commands go in fine, but the other:
Result of the command: "access-g outside_in interface outside"
ERROR: % Invalid input detected at '^' marker.
ups, sorry. try now:
access-g outside_in in interface outside
  • looks like that worked!!!
also I want access too the owa page via HTTPS, would the commands be:
static (inside,outside) tcp interface https 192.168.1.101 https
access-l outside_in permit tcp any interface outside eq https
correct
this line is only needed once
Thank you for all your help, I have learnt alot tonight thanks too u!!! - i'll be asking you again defo!!
Lastly, how do I save the entire config just incase it goes pop.
yes save the config using the command "write mem"
I've done that, I mean save it as a file in some way.
sure you can do that. the easiest way is to do "show run" then copy and paste the config into a text file.
