PIX 515e Inbound Routing Problem
annuletincorporated
Community Member
I can't get our PIX to accept inbound traffic. I'm a Cisco newbie, and so using the PDM to configure the hosts, access rules, and translations.
Everything behind the PIX works, as far as hosts externally resolving with the correct ips, having the ability to browse, dns, etc. Even internal cross-vlan access with working find between the interfaces.
>> I have static translations to public ips definbed for each host server.
>> I have access rules defined from "outside/any" to the host inside the firewall.
According to the documentation using the PDM, everything appears to eb setup correctly. Outbound and internal traffic is working, too.
Is it not possible to exclusively use the PDM to enable inbound traffic to internal hosts? Do I need to define additional access groupd, aaa, or something? Otherwise, where am I going wrong?
nkhawaja
we need the config (hide the ip addresses)
collect syslog messages
