PIX and FTp problems
jbernard
Community Member
We have a PIX running 4.4(5). When accessing and internal FTp server form the outside, random connections time out. We ave tried passive mode with no improvement.
Any other ideas?
Brian
steve.barlow
Level 10
Level 10
Not sure if this applies to you: bug CSCds48493
First thought is to upgrade the OS to at least 5.x if not 6.x.
Hope it helps.
Steve
steve.barlow
Level 10
Level 10
Hope it helps.
Steve
Steve,
Thanks for the tip. That looks like it may be the issue. I was looking for the incentive to get the PIX software updated.
Brian
If you want to stay on the 4.4 train specifically (some customers like to), then you can upgrade to 4.4(8) for the fix. Otherwise any v5 or v6 code should be fine.
