PIX connection problem
kash
Community Member
hi.....
my network config is that..
A(network)-Router-router1-------pix-router2-internet
......... server(Unix,linux,win200server)
config pix open some tcp and all icmp,and using nat0
pix sec100:public, sec0:private address using.
server all default gateway is router1
router has routing default is router2
problem is that.
first some servers ping from router2,and some doesn't
time later some server isn't connect.
so I act some server to ping router2, and the router2
and ping or other connection.
no physical or arp problem.
IF anyone knows this problem ?
and give me a answer....
please let me know
email: [email protected]
thanks......
mhussein
Level 9
Level 9
If I understand correctly, this seems to be an arp cache problem. Try clearing the arp cache on both routers, then clear pix translations ...
