PIX failover problem
mievers
Community Member
I have a pix 515 with stateful failover, we had a power outage and the primary will not re-assume primary status. If I turn both off and then turn on the primary we have no outside access. If I turn on the failover unit we get access back. when I do a show failover I see the following:
TCCPIX(config)# sh failover
Failover Off
Cable status: Normal
Failover unit Secondary
Failover LAN Interface: not Configured
Unit Poll frequency 15 seconds, holdtime 45 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 6 of 250 maximum
How do I get the Failover On?
JORGE RODRIGUEZ
Level 11
Level 11
Hi, are your pixes failover connected by serial cable or lan base failover? either serial/lan base failover check failover physical connections, to enable failover bring-up the active and issue failover from enable mode to enable failover , do same for standby.
go over this link if running code 7.x
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#acti
if runnign code 6.x
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094ea7.shtml
Rgds
Jorge
Jorge Rodriguez
