PIX problem ,3 Questions
kinanshahid
Community Member
Hi, I need help regarding to given Questions.
Pix Configuration is Attach.
Question 1
The VPN does not work. What do I do to fix it?
Question 2
What model of Pix is this?
Question 3
What do you thing anything should be added,removed or changed in this configuration to make it better?
mmorris11
Level 9
Level 9
Q1: Hard to say for sure but it looks like you need to enable isakmp on the outside interface.
Q2: Post a "sh ver" for this information
Q3: This is highly speculative and would require full scenario depiction of all the applications of this device.
jwalker
Level 7
Level 7
Q1
You need to add the nonat for the inbound VPN traffic. Also, can you do a sho ipsec sa and sho isakmp sa? Here is a nonat commands...
nat (inside) 0 access-list VPN
Q2
To find out the model number do a sho version. If you don't understand the output, post it here and I will let you know.
Q3
Everything else looks OK...
If this helps in any way, please rate.
cheers!
