Port forwarding using fdm
Innovative Network, Inc.
Community Member
I have a cisco firepower 1010.  I have used cisco asa's before and can forward ports on them but firepowers fdm are a little different and I can't seem to figure out how to forward ports on it.  Can somebody give me a step by step to forward ports on this firepower 1010 using the fdm.
Hi sorry to hear it did not work for you here find a solution for you in this article there is a nat rule same according to your requirements port forwarding here
please do not forget to rate.
Sheraz.Salim
here this link help you and this
Sorry to get back to you so late been really busy. But I tried following the video but somethings are different from the video and does not seem to work. 1 It says to create an object for the nat translated object from the outside.  I would think I would just use the ip that is on the outside interface which I did. 2 Then it says to make an auto nat rule and I did on the original packet side source interface any, original address as the internal server I want it to go to. Then I have tried it with original port as http (80) and as any.  I did the translated packet with destination Interface outside, translated address as interface and translated port as any.
Then on access control I did allow as the action ( I also tried just to see trust temporarily) and I put the source network as any-ipv4 and source ports as http (80).  then under destination I did networks as my inside server and ports/protocols as any and as http (80) and moved it to the top of the list and nothing seems to work.
What am I doing wrong that this will not seem to forward the port.
On the first link you sent what I am trying to do is it
I am not sure which one it is called for just opening a port for people to get to the site.
Thank you
This was exactly what I needed. I could not find it with google for some reason to save my life. Thank you very much
