PPPoE FTP ASA 5505
jill.kane
We are trying to set up our ASA 5505 that is running PPPoE so that we may access our ftp site using 99.23.119.78 to reach internal ip 192.168.1.3. Can someone tell me what I am missing?
Here is my current config:
Result of the command: "show running-config"
: Saved
ASA Version 8.2(1)
hostname ciscoasa
enable password qVQaNBP31RadYDLM encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif ATT
security-level 0
pppoe client vpdn group ATT
ip address pppoe setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object-group service DM_INLINE_TCP_1 tcp
port-object eq ftp
port-object eq ftp-data
access-list ATT_access_in extended permit tcp any host 99.23.119.78 object-group DM_INLINE_TCP_1
access-list ATT_access_in extended permit tcp any interface ATT eq ftp
access-list ATT_access_in extended permit tcp any interface ATT eq ftp-data
access-list 100 extended permit tcp any interface ATT eq ftp
access-list 100 extended permit tcp any interface ATT eq ftp-data
access-list 100 extended permit tcp any host 192.168.1.3 eq ftp
access-list 100 extended permit tcp any host 192.168.1.3 eq ftp-data
access-list 100 extended permit tcp any host 192.168.1.3 eq www
access-list extended extended permit tcp any host 192.168.1.3 eq ftp
access-list extended extended permit tcp any host 192.168.1.3 eq ftp-data
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu ATT 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (ATT) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,ATT) interface 192.168.1.3 netmask 255.255.255.255
access-group ATT_access_in in interface ATT
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 ATT
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group ATT request dialout pppoe
vpdn group ATT localname eossolutions@static.att.net
vpdn group ATT ppp authentication pap
vpdn username eossolutions@static.att.net password ********* store-local
dhcpd auto_config ATT
dhcpd address 192.168.1.5-192.168.1.132 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:8cb524a17e7417a6d17d6f1fa28be90b
: end
6 Replies 6
mirober2
Hi Jill,
What part of the config isn't working for you? Let us know where you're stuck and we can provide some guidance on how to troubleshoot.
-Mike
We are unable to reach our FTP site by browsing to ftp://99.23.119.78. Internally we are fine but our customers need to access the ftp site.
Can you test and provide any feedback, please and thank you!
Hi Jill,
Everything on the ASA seems to be correct. In fact, I can FTP to your server and get a login prompt:
C:\Users\mirober2>ftp 99.23.119.78
Connected to 99.23.119.78.
220 192.168.1.3 FTP server ready
User (99.23.119.78:(none)):
Could the problem be on your customer's side?
-Mike
I am unable to test the ftp site using the external ip address 99.23.119.78 from inside the network. Do you know what I have to do to
route this?
Also, there is a port for utilizing a web gui using port 9000 but we would like to actually be able to not have to enter the port number and just have an http url go directly to the gui by the following url: http://www.fileshare.3eos.com. We were previously able to use the web url as http://www.fileshare.3eos.com:9000.
Please let me know...
I dont think you should be using the following static
As you may have internet connectivity.....
However, if you want to use the FTP using the public IP, what you would need to do is the following
static (Inside,inside) 99.23.119.78 192.168.1.3
nat (inside) 1 0 0
global (inside) 1 interface
same-security-traffic permit intra-interface....
Let me know how it goes.
Mike
Mike
Well I tried your suggestion and that didn't work. I am still unable to reach our ftp site internally by using the external IP address.
I am also trying to forward any http request to port 9000 so that when our customers connect to our ftp's web interface they don't have to enter the port number in the url http://99.23.119.73:9000 I'd like for the customers to just be able to access http://99.23.119.78.
My current config is as follows:
: Saved
ASA Version 8.2(1)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif ATT
security-level 0
ftp mode passive
port-object eq ftp
port-object eq www
access-list ATT_access_in extended permit tcp any interface ATT eq www
access-list extended extended permit tcp any host 192.168.1.3 eq www
pager lines 24
logging enable
mtu inside 1500
mtu ATT 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 ATT
ssh timeout 5
console timeout 0
dhcpd enable inside
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
: end
