prevent DDOS in low speed link
xwang2
Hi all:
Should we configure some Qos feature in a low speed serial link to prioritize the ospf routing packet in a low speed FR link in case of under DDOS attack. If could , how could we do the configure ?
Nairi Adamian
For prioritizing routing update on FR network, one way I can think of is setting the discard Eligible bit on all traffic except routing update.
http://www.cisco.com/warp/customer/105/config_fr_pvc.html
Hope this helps,
-Nairi
Thanks,Nairi:
I will try this in real network and give you result later.
