Problem configuring Cisco 501
aleksandarmijalkovic
Community Member
Hello
I have a Cisco 501 and I can not get into the configuration menu of the Java console appears to me this script
basic: Added progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@11c8a71
basic: Plugin2ClassLoader.addURL parent called for https://192.168.1.1/jploader.jar
security: Blacklist revocation check is enabled
security: Trusted libraries list check is enabled
network: Cache entry found [url: https://192.168.1.1/jploader.jar, version: null] prevalidated=false/0
network: Connecting https://192.168.1.1/jploader.jar with proxy=DIRECT
network: Connecting http://192.168.1.1:443/ with proxy=DIRECT
security: Loading Root CA certificates from D:\Program Files\Java\jre6\lib\security\cacerts
security: Loaded Root CA certificates from D:\Program Files\Java\jre6\lib\security\cacerts
security: Loading SSL Root CA certificates from D:\Program Files\Java\jre6\lib\security\cacerts
security: Loaded SSL Root CA certificates from D:\Program Files\Java\jre6\lib\security\cacerts
security: Loading Deployment SSL certificates from D:\Documents and Settings\AleksandarMijalkovic\Application Data\Sun\Java\Deployment\security\trusted.jssecerts
security: Loaded Deployment SSL certificates from D:\Documents and Settings\AleksandarMijalkovic\Application Data\Sun\Java\Deployment\security\trusted.jssecerts
security: Loading certificates from Deployment session certificate store
security: Loaded certificates from Deployment session certificate store
security: Loading certificates from Internet Explorer ROOT certificate store
security: Loaded certificates from Internet Explorer ROOT certificate store
security: Checking if certificate is in Deployment denied certificate store
security: Checking if certificate is in Deployment session certificate store
security: Checking if SSL certificate is in Deployment permanent certificate store
network: Firewall authentication: site=/192.168.1.1:443, protocol=https, prompt=PIX, scheme=basic
network: ResponseCode for https://192.168.1.1/jploader.jar : 304
network: Encoding for https://192.168.1.1/jploader.jar : null
network: Disconnect connection to https://192.168.1.1/jploader.jar
cache: Reading Signers from 2858 https://192.168.1.1/jploader.jar | D:\Documents and Settings\AleksandarMijalkovic\Application Data\Sun\Java\Deployment\cache\6.0\43\4cca7fab-35ee7b26.idx
cache:  Read manifest for https://192.168.1.1/jploader.jar: read=134 full=2069
security: Loading Deployment certificates from D:\Documents and Settings\AleksandarMijalkovic\Application Data\Sun\Java\Deployment\security\trusted.certs
security: Loaded Deployment certificates from D:\Documents and Settings\AleksandarMijalkovic\Application Data\Sun\Java\Deployment\security\trusted.certs
security: Loading certificates from Internet Explorer TrustedPublisher certificate store
security: Loaded certificates from Internet Explorer TrustedPublisher certificate store
security: Validate the certificate chain using CertPath API
security: Obtain certificate collection in Root CA certificate store
security: No timestamping info available
security: Found jurisdiction list file
security: No need to checking trusted extension for this certificate
security: The CRL support is disabled
security: The OCSP support is disabled
security: This OCSP End Entity validation is disabled
security: Checking if certificate is in Deployment permanent certificate store
basic: updateValidationResultsForApplet update
cache: Mark prevalidated: https://192.168.1.1/jploader.jar true tm=1291301686859 cert=1132444799000
cache: Mark prevalidated: https://192.168.1.1/jploader.jar true tm=1291301686890 cert=1132444799000
basic: Plugin2ClassLoader.getPermissions CeilingPolicy allPerms
basic: Applet loaded.
basic: Applet resized and added to parent container
basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 522854 us, pluginInit dt 37038932 us, TotalTime: 37561786 us
network: Cache entry found [url: https://192.168.1.1/pdm.sgz, version: null] prevalidated=false/0
network: Connecting https://192.168.1.1/pdm.sgz with proxy=DIRECT
network: ResponseCode for https://192.168.1.1/pdm.sgz : 304
network: Encoding for https://192.168.1.1/pdm.sgz : null
network: Disconnect connection to https://192.168.1.1/pdm.sgz
basic: Applet initialized
basic: Removed progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@11c8a71
basic: Applet made visible
basic: Starting applet
basic: completed perf rollup
network: Connecting https://192.168.1.1/exec/show%20running-config with proxy=DIRECT
network: Connecting https://192.168.1.1/exec/show%20pdm%20sessions with proxy=DIRECT
network: Connecting https://192.168.1.1/exec/show%20version with proxy=DIRECT
network: Connecting https://192.168.1.1/exec/show%20curpriv with proxy=DIRECT
java.lang.ArrayIndexOutOfBoundsException: No such child: 0
at java.awt.Container.getComponent(Unknown Source)
at symantec.itools.b.n.getComponent(Unknown Source)
at java.awt.Component.calculateCurrentShape(Unknown Source)
at java.awt.Component.applyCurrentShape(Unknown Source)
at java.awt.Component.mixOnShowing(Unknown Source)
at java.awt.Component.addNotify(Unknown Source)
at java.awt.Label.addNotify(Unknown Source)
at java.awt.Container.addNotify(Unknown Source)
at java.awt.Panel.addNotify(Unknown Source)
at symantec.itools.b.n.addNotify(Unknown Source)
at java.awt.Window.addNotify(Unknown Source)
at java.awt.Frame.addNotify(Unknown Source)
at java.awt.Window.show(Unknown Source)
at com.cisco.pdm.PDMApplet.start(Unknown Source)
at com.cisco.nm.util.sgz.Env.start(Env.java:37)
at com.cisco.nm.util.sgz.Loader.start(Loader.java:109)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Exception: java.lang.ArrayIndexOutOfBoundsException: No such child: 0
Ignored exception: java.lang.ArrayIndexOutOfBoundsException: No such child: 0
basic: setting up a new GraBoxPainter for Error
basic: Applet started
basic: Told clients applet is started
and nothing happens
Thanks in advance
cadet alain
Whic OS and which PDM version ? what is your JRE version and which browser are you using( version).
Regards.
PDM is 3.0(4)
Java is 1.6
Broser is IE 8
Java 1.6.what? and Pix OS?
regards.
Hola tengo un problema igual con un Cisco PIX 506E, tiene el
PIX OS Pix635.bin
PDM-304.bin
Para acceder al PDM uso
IExplorer 7
Java Plug-in 1.6.0_27
Using JRE version 1.6.0_27-b07 Java HotSpot(TM) Client VM
pero tengo el mismo problema adjunto log del panel de Java
at java.awt.Dialog.addNotify(Unknown Source)
at com.cisco.pdm.h.z.addNotify(Unknown Source)
at java.awt.Dialog.conditionalShow(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at com.cisco.pdm.h.kv.show(Unknown Source)
at com.cisco.pdm.h.l$a.run(Unknown Source)
java.lang.NullPointerException
at com.cisco.pdm.StartupWizApplet.start(Unknown Source)
Exception: java.lang.NullPointerException
basic: Told clients applet is started java.lang.ArrayIndexOutOfBoundsException: No such child: 0
he buscado por todos lados solucion y aun no encuentro, esperando su ayuda agradesco de antemano la atencion.
