Problem continues~
SPERTWCISCO
Community Member
Sorry for opening another thread, but I keep getting the following error:
ZR1(config)# class-map inspection_default
ZR1(config-cmap)# match default-inspection-traffic
ZR1(config-cmap)# policy-map type inspect dns preset_dns_map
ZR1(config-pmap)# parameters
ZR1(config-pmap-p)# message-length maximum 512
ZR1(config-pmap-p)# policy-map
ZR1(config-pmap-p)# policy-map gl
ZR1(config-pmap-p)# policy-map global
ZR1(config-pmap-p)# policy-map global_policy
ZR1(config-pmap)# class in
ZR1(config)# class inspection_default
ZR1(config-cmap)# inspect dns present_dns_map
ERROR: % Invalid input detected at '^' marker.
Also, how do I configure the ASA to block out spyware or ads when viewing from www? Do I need to know the URL to do this?
thx
Jennifer Halim
Here is the sequence for the configuration:
Please make sure that you type in the full "inspection_default" name otherwise, it is going back to the "config" mode, not within the policy-map mode.
In regards to spyware and adware, ASA is not able to block those. You would need to have CSC module on your ASA to block the spyware and adware.
Hope that helps.
For some reason, it won't accept the command.
I had to "write erase" the whole config and now is finally working.
Here is my final running-config.
How can I harden it even more?
As well, what is the following command? Can I delete or disable it?
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
thx
: Saved
ASA Version 8.3(1)
hostname xxxxx
enable password xxxxxxxxxxxx encrypted
passwd xxxxxxxxxx encrypted
names
interface Vlan200
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan500
no forward interface Vlan800
nameif dmz
security-level 50
ip address 10.2.1.1 255.255.255.0
interface Vlan800
nameif inside
security-level 100
interface Ethernet0/0
switchport access vlan 200
interface Ethernet0/1
switchport access vlan 800
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 500
boot system disk0:/asa831-k8.bin
ftp mode passive
clock timezone xxxxx
object network obj_any
subnet 0.0.0.0 0.0.0.0
access-list outside_access_in extended deny ip any any
access-list dmz_access_in extended deny ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu dmz 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
access-group outside_access_in in interface outside
access-group dmz_access_in in interface dmz
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 30
ssh version 2
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.8-192.168.1.10 inside
dhcpd dns [ISP DNS1] [ISP DNS2] interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username xxxxxxxx password xxxxxxxxx encrypted
parameters
  message-length maximum client auto
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
Cryptochecksum:xxxxxxxxxxxxxxxx
: end
1) You do not need to configure ACL on the outside interface if you are not initiating inbound connection because by default, traffic from outside (low security level) to inside/dmz (higher security level) will be denied.
The following can be removed:
2) You have the following ACL: "access-list dmz_access_in extended deny ip any any" applied to dmz: "access-group dmz_access_in in interface dmz", which means dmz hosts are not able to initiate any connection at all towards inside and outside. Not sure if this is what you are after, but if it is, you are on the right track.
3) I also see that you have no ACL applied to your inside interface. If you want to restrict access more, you can configure ACL and applied it to the inside interface for traffic from inside towards dmz and outside. Because by default, traffic from higher security level towards lower security level is allowed. So you can restrict access from inside towards dmz and outside with specific ACL.
Hope that helps.
Magnus Mortensen
The reason you are having issues is becuase it looks like you are using tab completion when typing the class line:
Notice the prompt change? Tab completion when doing the class line results in dumping back to the (config) prompt and out of the (config-pmap) sub config. If you did not hit tab, it should have kept you in that config mode and it should have worked.
-M
