Problem in OBJECT GROUP is asa 5520
prashantrecon
Hi All,
I have created a object group and a access list as given below.
object-group network MOBILE_IN
access-list MOBILE extended permit ip object-group MOBILE_IN any
static (inside,outside) x.x.x.x  access-list MOBILE
Now my problem is that
By this configuration every website working fine except YOUTUBE.
When i open youtube it take much time to open and when i tried to play and video it not played.
other sites video like msn video ,rediff video working fine.
can any one give a clue why its happen.
Prashant
7 Replies 7
prashantrecon
Hi All,
When i check log
its say that
6    Oct 17 2011    09:52:49    302014    74.125.232.193    80    172.16.6.131    1892    Teardown TCP connection 16226049 for outside:74.125.232.193/80 to inside:172.16.6.131/1892 duration 0:04:00 bytes 0 TCP Reset-I
Hello Kumar,
As we can see here the TCP connection is being closed, this because a reset and these reset is comming from the inside,so this means the inside user is sending a reset message and the connection is being dropped.
You will need to take a look at the inside PC , I am quite sure that if you take some captures you are going to see the internal host sending this message, so the ASA is not the one  dropping the connection.
Hope you have a great day.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi Prashant,
The log doesn't seem the right one to me:
The ip 74.125.232.193 is for google not youtube.
To troubleshoot this issue, take the correct logs and take captures when you access youtube.
In the logs chcek the reason for teardown and in the captures check if there is any delay from the ASA. Wjat time the packet takes to once it enters to the inside interface to the time it leaves the outside interface.
This should be your troubleshooting steps.
For captures:
https://supportforums.cisco.com/docs/DOC-17814
Varun
Varun Rao
Hi Varun,
when i did nslookup from my machine it's display as
C:\Documents and Settings\Administrator>nslookup youtube.com
Server:  vnsc-bak.sys.gtei.net
Address:  4.2.2.2
Non-authoritative answer:
Addresses:  74.125.232.192, 74.125.232.193, 74.125.232.194, 74.125.232.195
          74.125.232.196, 74.125.232.197, 74.125.232.198, 74.125.232.199, 7
.232.200
          74.125.232.201, 74.125.232.202, 74.125.232.203, 74.125.232.204, 7
.232.205
          74.125.232.206, 74.125.232.207
can you tell me possible reason ? why my pc is sending reset request ?
When i use my pc to use proxy server then youtube working fine.
Hello Kumar,
At this moment we can see that the ASA is not the one dropping the connections as the Internal reset, now is is hard to figure out why a PC is sending a reset message but one reason a device will send a RST is in response to receiving a packet for a closed socket, but to define why this is happening is really hard because every possible perversion has been visited on TCP since its inception.
I would recommend to use a packet sniffer ( Wireshark ) on the PC and confirm that the PC is the one sending the reset message when you make the connection.
Please take some captures and let us know the result.
Julio
Julio Carvajal
plz find attachment with name
youtube wireshark capture
please use filter for my machine ip 172.16.6.131 .
Prashant
