Problem Nat with Asa 5520 vers 8.4
lbellicaud
Hi All,
I want to set up NAT with ASDM on ASA for a client and I can not make it work.
Let me explain, I have several interface:
Inside: 10.97.0.1 / 24
Outside: 10.0.1.70 /24
Interco: 192.168.6.1 /24
Other Sites: 10.26.0.4 /24
All routing in the network is Ok
My customer want to access a server @ ip 10.194.70.1 in https on the interface Interco with his nat address as 10.97.0.11 .
This server must be accessible with the address 10.97.0.11:443 from interfaces inside, outside and other sites.
And source address must be nated with original destination address 10.97.0.11 to be redirected on 10.194.70.1.
You can use just one single sattement for it as well:
object network natted_ip
  host 10.97.0.11
object network real_ip
  host 10.194.70.1
object network Natted_SourceIP
host 10.97.0.254
object service tcp_443
  service tcp source eq 443
nat (inside,Interco) source dynamic any Natted_SourceIP destination static natted_ip real_ip service tcp_443 tcp_443
Hope this helps.
Varun
Varun Rao
7 Replies 7
varrao
Level 10
Level 10
I am not sure about your exact requirement, can you just write the requirements in from of each question???
Behind whihc interface is teh server connected??
Real ip of server??
Wat should be the natted ip of server???
should it be accessible from all other 3 interafces???
Varun
Varun Rao
Hi Varun,
Server is on remote site and can be reached by the interface Interco.
Real ip: 10.194.70.1
Natted ip:10.97.0.11
It should be accessible from all other interfaces with Natted Address.
thanks
You would need this nat statement:
  host 10.97.0.11
  host 10.194.70.1
nat (Interco,any) source static real_ip natted_ip service tcp_443 tcp_443
Hope this helps,
Varun
Varun Rao
Hi Varun,
it's not that simple, it is necessary that the real addresses access to the server are nated with the same address 10.97.0.11 on the interface Interco.
thanks
I am sorry i didnt get your question correct, do yu want the source addresses that access the server to be natted to the same ip 10.97.0.11 as well???
Well if thats your query then it is not possible, you cannot nat the source and the destination to the same ip.
-Varun
Varun Rao
Hi Varun,
excuse for the delay!!
Then, i can translate my source with another address for example: 10.97.0.254???
  host 10.97.0.11
  host 10.194.70.1
host 10.97.0.254
nat (inside,interco) source dynamic any Natted_SourceIP any
Laurent
  host 10.97.0.11
  host 10.194.70.1
host 10.97.0.254
Hope this helps.
Varun
Varun Rao
