Problem passing traffic outside the pix
eelliston
Community Member
I am having an issue where all wanted traffic can get in (Webpages, DNS, SMTP, etc.) but no machine from the inside can get out....even with a ping.
I attached my config,
When I try to ping to the outside from inside, I get this error logged...
305006: portmap translation creation failed for icmp src inside:192.168.4.22 dst outside:63.243.97.154 (type 8, code 0)
I also see this for UDP as well...
Any help would be great!
jmia
Level 11
Level 11
Eric,
I had a quick look at your config and one thing I noticed is that you dont't seem to have any access-group LANOut in interface inside applied, also for your reference check out the following URL on how to handle icmp traffic through the pix.
http://www.cisco.com/warp/public/110/31.html
Also, remember to issue clear xlate after any modifications to ACLs or statics and save with write mem.
Hope this helps,
Jay
eelliston
Community Member
Humm, in with the acl applied (access-group LANOut in interface inside) and clearing the xlate...same problem.
Can't ping...can't surf...humm..
thanks!
eelliston
Community Member
Oh, and another thing...
The devices on the inside (windows servers) have 2 IPs on the interface. One is 192.168.4.x the other is 192.168.64.x,192.168.65.x or 192.168.68.x.
I do a translation to that network (one to one)...which seems to work fine.
The problem is when I try to surf outside....the machines primary ip is the 192.168.4.x network, which has a one to many translation (PAT). I dunno why...the client wanted it this way for some reason.
Maybe that will help figure out whats up.
Thanks!
