Problem using 2 outside interfaces
davistw
Level 3
Level 3
I am trying to do is setup a pix with 2 outside interfaces (See Drawing 1). Below is the configuation.
Building configuration...
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet0 vlan16 logical
interface ethernet1 auto
interface ethernet1 vlan3 logical
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif vlan3 inside_pc_vlan3 security99
nameif vlan16 outside_pc_vlan16 security1
/SNIP/
access-list 101 permit ip any any
access-list inside_pc_vlan3_access_in permit ip 192.168.6.0 255.255.254.0 192.168.5.0 255.255.255.0
access-list inside_pc_vlan3_access_in permit ip 192.168.6.0 255.255.254.0 any
/SNIP/
ip address outside 192.168.136.2 255.255.255.0
ip address inside 192.168.5.254 255.255.255.0
ip address inside_pc_vlan3 192.168.7.254 255.255.254.0
ip address outside_pc_vlan16 192.168.26.2 255.255.254.0
/SNIP/
global (outside) 1 192.168.136.20-192.168.136.245
global (outside) 1 interface
global (outside_pc_vlan16) 16 192.168.26.20-192.168.27.245
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (inside_pc_vlan3) 16 0.0.0.0 0.0.0.0 0 0
/SNIP/
static (inside,inside_pc_vlan3) 192.168.5.0 192.168.5.0 netmask 255.255.255.0 0 0
access-group 101 in interface outside
access-group inside_pc_vlan3_access_in in interface inside_pc_vlan3
route outside 0.0.0.0 0.0.0.0 192.168.136.1 1
/SNIP/
When I try to connect from a PC on inside_pc_vlan3 to an external machine I get the following error:
%PIX-3-305006: portmap translation creation failed for tcp src inside_pc_vlan3:192.168.6.1/2802 dst outside:192.168.133.207/80
However, when I move inside_pc_vlan3's nat to the outside interface via
Everthing works except it is using the wrong interface and wrong nat pool...
I think the error is in the routing because fromt the error it appears that the failure is on the "outside" interface but I don't know how to fix it.
Recommendations?
15 Replies 15
Thanks...
