Problem when adding a sensor to IDS MC
oabduo983
Level 5
Level 5
Hi All,
Any body has come across the problem I'm facing here? I'm adding 4 sensors to my IDS MC (2.2) and I'm getting an error message when I tried to add the third one, I clicked on (show message) and I got the attached output... please advise of how can I troubleshoot/fix this problem...
Appreciate your cooperation...
npham
Level 3
Level 3
Regenerate the sensor's certificate. Usually this is because the sensor's certificate has expired. Then go back to IPS MC, and add the sensor.
For 5.x sensor, through IDM:
Configuration > Sensor Setup > Certificates > Server Certificate
click Generate Certificate
For 4.x sensor, through IDM:
Device > Sensor Setup > Certificate > Generate Host Certificate
click Apply to Sensor
npham
Level 3
Level 3
