Problem with AnyConnect when we try to connect.
Hello Team,
Some users have problems connecting to anyconnect. Previously it worked for them, but since Windows was updated (The last December) it gives them error.
>>>  [Device Install (UpdateDriverForPlugAndPlayDevices) - VPNVA]
!!!  ndv:      Device install failed for device.
     ndv: {Update Device Driver - exit(000005b4)}
!!!  ndv: Failed to install device instance 'ROOT\NET\0000'. Error = 0x000005b4
<<<  Section end 2017/12/22 14:55:56.428
<<<  [Exit status: FAILURE(0x000005b4)]
I have tried to re-install anyconnect, (From scratch, disabling the antivirus, ...), But it doen´t work.
Please, Any idea?.
Thank you.
Best Regards
Ajay Saini
Level 7
Level 7
Hi Ajay,
Thanks for your time.
I tried all tips about recent thread that you told me, but it doesn´t work.  :(
I continue researching.
Thank you.
Best Regards,
