Problem with ASA packet tracer
TreCani
Visitor
Hi everybody,  i'm trying to config my ASA 5505. But it drop both icmp packets and telnet connection from allowed host, also after i've created an access-list... i post the asa running conf:
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.1 192.168.1.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.255.2 255.255.255.252
route inside 192.0.0.0 255.0.0.0 192.168.1.5 1
route outside 0.0.0.0 0.0.0.0 192.168.255.1 1
access-list OUTSIDE extended permit tcp host 172.16.0.1 any eq telnet
access-list OUT-IN extended permit icmp any any
telnet timeout 5
ssh timeout 5
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
I also show you the result with a ping of a host inside
Thank you for your help
Bogdan Nita
I believe you did not apply the created acls to the outside interface, in order to do that for the OUT-IN acl you would need to enter the following command:
access-group OUT-IN in interface outside
Bogdan
Bogdan Nita
Bogdan
Hi Bodgan;
thank you so much!!
