Problem with cisco 5510 port mapping
raidokuvarnet
My device Cisco ASA 5510, ASA 8.4(2), ASDM 6.4(5)206
What I try to achieve.
1) Host 10.10.11.108 listening port 8080
2) Trying to access it from WAN e.g port 8090
I tried following commands:
object network 10.10.11.108_8080
host 10.10.11.108
nat (LAN1,WAN) static interface service tcp 8080 8090
access-list WAN_access_in line 11 extended permit tcp any object 10.10.11.108_8080 eq 8080
access-group WAN_access_in in interface WAN
But I don't gett access. Can someone help me to solve this case?
I think I know what the problem is:
object service tcp-8080
service tcp destination eq 8080
object service tcp-8090
service tcp destination eq 8090
change it to source instead of destination:
service tcp source eq 8080
service tcp source eq 8090
no access-list WAN_access_in extended permit object tcp-8080 any object 10.10.11.108_8080
access-list WAN_access_in extended permit tcp any object 10.10.11.108_8080 eq 8080
Please remember to select a correct answer and rate helpful posts
33 Replies 33
Aditya Ganjoo
Can you share the packet tracer output for the concerned traffic ?
packet-tracer input WAN tcp 4.2.2.2 6767 <interface> 8090 det
Aditya
Please rate helpful posts and mark correct answers.
I don't know how to save packet tracer output, but here is a screenshot of it.
Packet-tracer is showing a NAT RPF drop.
So the return traffic is taking a different NAT.
Could you remove the existing NAT and create a manual NAT ?
nat (inside,outside) 1 source static 10.10.11.108_8080 interface service tcp-8080 tcp-8090
This should work !!!
Aditya
Actually you have used the wrong IP in the destination of the packet-tracer.  it should not be 10.10.11.108, so replace it with the WAN interface IP and then run the packet tracer again.
Okay, lets give it another try:
Try Aditya's suggestion of removing the object NAT statement and configuring the NAT in manual NAT.
nat (LAN1,WAN) 1 source static 10.10.11.108_8080 interface service tcp-8080 tcp-8090
If that still does not work, please post a full running config of the ASA (remove any usernames, passwords and public IPs)
Result of the command:
"nat (LAN1,WAN) 1 source static 10.10.11.108_8080 interface service tcp 8080 tcp 8090"
nat (LAN1,WAN) 1 source static 10.10.11.108_8080 interface service tcp 8080 tcp ^8090
ERROR: % Invalid input detected at '^' marker.
You are missing the -   tcp-8080 and tcp-8090
Result of the command: "nat (LAN1,WAN) 1 source static 10.10.11.108_8080 interface service tcp-8080 tcp-8090"
ERROR: tcp-8080 is not a valid service object name
ah ok...you have probably configure the service object incorrectly by using the destination keyword.
You need to configure it as follows:
object-group service tcp-8080 tcp
port-object eq 8080
Ran these commands, but error is the same:
Should it be?:
service-object eq 8080
is this the correct command to run?
Try using an underscore instead of hyphen.  Also it is port-object not service-object.
object-group service tcp_8080 tcp
port-object eq 8080
Result of the command: "object-group service tcp_8080 tcp"
The command has been sent to the device
Result of the command: "port-object eq 8080"
Result of the command: "nat (LAN1,WAN) 1 source static 10.10.11.108_8080 interface service tcp_8080 tcp-8090"
ERROR: tcp_8080 is not a valid service object name
Result of the command: "nat (LAN1,WAN) 1 source static 10.10.11.108_8080 interface service tcp_8080 tcp_8090"
