Problem with cisco 5510 port mapping
raidokuvarnet
My device Cisco ASA 5510, ASA 8.4(2), ASDM 6.4(5)206
What I try to achieve.
1) Host 10.10.11.108 listening port 8080
2) Trying to access it from WAN e.g port 8090
I tried following commands:
object network 10.10.11.108_8080
host 10.10.11.108
nat (LAN1,WAN) static interface service tcp 8080 8090
access-list WAN_access_in line 11 extended permit tcp any object 10.10.11.108_8080 eq 8080
access-group WAN_access_in in interface WAN
But I don't gett access. Can someone help me to solve this case?
33 Replies 33
Result of the command: "packet-tracer input wan tcp 4.2.2.2 8888 80.250.119.69 8090 det"
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in id=0xda1d5568, priority=1, domain=permit, deny=false
hits=5697523304, user_data=0x0, cs_id=0x0, l3_type=0x8
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0100.0000.0000
input_ifc=WAN, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 80.250.119.69 255.255.255.255 identity
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in id=0xd9364000, priority=0, domain=permit, deny=true
hits=463202, user_data=0x9, cs_id=0x0, use_real_addr, flags=0x1000, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: WAN
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
hmm, doesn't seem to be hitting the NAT rule.
Could you post the output of "show nat 10.10.11.108"
Please remember to select a correct answer and rate helpful posts
Result of the command: "show nat 10.10.11.108"
Manual NAT Policies (Section 1)
1 (LAN1) to (WAN) source static 10.10.11.108_8080 interface service tcp-8080 tcp-8090
translate_hits = 0, untranslate_hits = 0
3 (LAN1) to (WAN) source static obj_10.10.11.108 interface service 37777 37777 description KK 12.08.2013 Securer videovalve
translate_hits = 0, untranslate_hits = 33
I think I know what the problem is:
object service tcp-8080
service tcp destination eq 8080
object service tcp-8090
service tcp destination eq 8090
change it to source instead of destination:
service tcp source eq 8080
service tcp source eq 8090
no access-list WAN_access_in extended permit object tcp-8080 any object 10.10.11.108_8080
access-list WAN_access_in extended permit tcp any object 10.10.11.108_8080 eq 8080
