Problem with HTTP inspection.
gloubier
Level 2
Level 2
I would like to find a way to give access to one website ( let say cisco.com ), give access to whatever website that have the word "test" in the URL and block the access to all the other websites for only one server ( let say the_server ).
Here the config I have now :
regex cisco.com "\.cisco\.com"
regex test "test"
regex all ".*"
access-list acl_test extended permit tcp object GLOUBIER any eq www
class-map inside-test
match access-list acl_test
class-map type inspect http match-all http_url_filtering_test
match request header host regex cisco.com
class-map type inspect http match-all http_url_filtering_test2
match request uri regex test
class-map type inspect http match-all http_url_filtering_test3
match request header host regex all
policy-map type inspect http http_url_inspection_test
parameters
class http_url_filtering_test
  log
class http_url_filtering_test2
  log
class http_url_filtering_test3
drop-connection
policy-map inside-policy
class inside-test
Those rules aren't working ( everything is blocked ), but if I'm try each class-map individualy, it's working fine.
Is there a way to make the 3 rules ( allow cisco.com, allow word test in URL, block the rest ) work together ?
Thanks for the answers and help.
mirober2
I would suggest flipping your logic around to drop everything that doesn't match your allowed requests like this:
regex cisco.com "cisco\.com"
regex test "test"
class-map type inspect http match-all filter-class
   match not request header host regex cisco.com
   match not request uri regex test
policy-map type inspect http filter-policy
   parameters
   class filter-class
      drop-connection
   class inside-test
That makes the config a bit more manageable and should do what you are looking for.
-Mike
mirober2
regex test "test"
   parameters
   class filter-class
      drop-connection
   class inside-test
-Mike
That solution makes sense.
I'll try that in the next days and let you know if it fixe my problem or not.
Thanks for the reply.
