Problem with IPS-sig-S224
netwave12345
Community Member
I'm experiencing an issue updating my IDSM-2's. I'm currently at 5.1(1p1)S223.0V1.0, I tried applying the latest signatures (S224), but failed and got the following message:
"Exception during sensor reimaging: Timed out while waiting for sensor to come up for SENSOR. Erorr(s) encountered during sensor update, this sensor update is aborted"
I tried it again on another sensor and got the same result. In both cases, the sensors became unresponsive and couldn't even reboot them from IPS MC, IDM, CLI.
Is anyone else having issues with the latest S224.
DSmirnov
Level 3
Level 3
Same or simular problem with S224 for 5.1d on IPS 4240. I can see package update script running on a sensor, it will never quit. Sensor reboot from shell helps, sensor reports 224 after reboot and working normally.
