Problem with NAPT on PIX 525
I have a PIX-525-UR, PIX OS 6.2(2) with several interfaces.
Having problem to get one IP on a DMZ to be able to use to different NAT rules, one to a DMZ with a lower security and another one to the outside.
like this:
nameif ethernet0 outside security0
nameif ethernet1 dmz1 security30
nameif ethernet2 dmz2 security25
nat (dmz1) 2 10.0.0.3 netmask 255.255.255.255 0 0
nat (dmz1) 1 10.0.0.0 netmask 255.255.255.0 0 0
global (outside) 1 interface
global (dmz2) 2 interface
NAT traversal to the outside works fine for all hosts on the 10.0.0.0/24 except those IP's specified in the NAT rule to the dmz2 interface, It seems like the pix can not handle more than one NAT rule for each source adress.
Has anyone seen this before, it seems to me that it is a limitation in the PIX OS on how many NAT rules can be used for the same source address.
Thanks in advance.
This is the SYSLOG message generated from the PIX:
%PIX-3-305006: portmap translation creation failed for tcp src dmz1:10.0.0.x/yyyyy dst outside:<some-address>/<port>
However reading the explanation to the message type at: http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/syslog/pixemsgs.htm#wp1020540
doesn't help me so much.
scoclayton
Level 7
Level 7
This will work fine actually. The problem is that you do not have a corresponding 'global (outside) 2 ' statement. The sequence number listed in the NAT command ties to the sequence number in the global command. Try adding:
global (outside) 2 interface
and see if that helps. It is important to remember that translations are created using the source and destination interfaces so you can have multiple translations for one source provided they have different destination interfaces.
Let me know if this is not clear.
Scott
Thanks.
That make sense to me, and is also how i expected it to be. However it doesn't work exactly that way, maybe I have misunderstod something. But anyway this is what i get typing the command you suggested:
pix1(config)# global (outside) 2 interface
Usage: [no] global [()] {[-] [netmask ]} | interface
The pix just doesn't accept the command, if I change the command to another interface, (dmz3) wich have security level 20, it works:
nameif ethernet4 dmz3 security20
pix1(config)# global (dmz3) 2 interface
dmz3 interface address added to PAT pool
Please let me know if you have some suggestions, and thanks again for helping.
