Problem with Pix Device Manager
aafkhami
Community Member
I have a pix525 with firewall version 6.1(1) and Device Manager version 1.1(2) both installed. Have also configured http access for my PC. License key is also capable of DES and 3DES.
When I try to connect to pix from my browser, I get this error message:
Your PIX image has a version number of unknown. This version of PDM will only interoperate with versions that start with 6.0 or 6.1. Please update your PIX image so that they are compatible.
Any ideas? Thanks in advance
Ali
quistr
Community Member
I got the same problem and it has something to do with the Java properties in your browser. I disabled Java(Sun) in tools/internet options/advanced and enabled the Microsoft VM checkboxes. This solved the problem.
I hope this will help you out.
Richard
