Problem with REST API using PUT
BenjaminChemla
Community Member
Hello community,
I currently have a problem using the CISCO FMC API.
I want to activate the logBegin and logEnd on all the rules of a policy (about 3000), I get all the rules with a GET request and then I loop on it to send a PUT request to modify the rules.
The PUT request I'm using is :
/api/fmc_config/v1/domain/{domain}/policy/accesspolicies/{uuid}/accessrules/{accessrules}
Everything works fine but i notice than if the rules have an "application" field then the request will send a status code 200 SUCCESS, but when I go back to my FMC I cannot access the “Access policy” anymore (I have a loading loop).
And If I don't send the field "application" this one is automatically removed from the rule.
Do you know how to modify rules that contains a condition on the Field “applications” ?
here is the problem rule:
Here is the body I send with my PUT request and that does not work:
  "id": "xxxxxxxxxx",
  "applications": {
    "inlineApplicationFilters": [
        "risks": [
            "type": "ApplicationRisk",
            "id": "VERY_LOW",
            "name": "Very Low"
            "id": "LOW",
            "name": "Low"
  "vlanTags": {},
  "logBegin": true,
  "logEnd": true,
  "variableSet": {
    "name": "Default Set",
    "id": "xxxxxxxxxxxxxxxxxx",
    "type": "VariableSet"
  "logFiles": false,
  "sendEventsToFMC": false,
  "type": "AccessRule",
  "action": "ALLOW",
  "name": "rule_application_test",
  "enabled": true
Here is a body without the application that works
  "id": "xxxxxxxxxx",
  "vlanTags": {},
  "logBegin": true,
  "logEnd": true,
  "variableSet": {
  "logFiles": false,
  "action": "ALLOW",
  "enabled": true
I want to clarify that the PUT works well with all the other Fields like syslog, destinationPorts, sourcesports, sourceZones, etc..
In addition I make all my requests (for the test) by going directly through the API-Explorer and nothing else and i'm using FMC version 6.2.2
In addition, is there a simple way to enable logging on all the rules of a policy directly (maybe bulk parameters) ?
Thank you for you precious help.
0 Replies 0
