Problem with SIP Trunk - random connection problems
ABaker94985
We recently migrated to a pair of 2140s and manage them with FMC. We're having random on-going problems with SIP, usually for 5 minutes or less a couple times at day at various locations. I'm not seeing any dropped packets in the connect events, and I've created a prefilter fastpath policy for this traffic. SIP is being inspected, and I was told today to make sure SIP ALG is disabled; however, I'm not sure where to do this at. I've not been able to track down documentation to do this within FMC. Can anyone point me in the right direction? Thank you.
You need to access firewall console then issue the following command
configure inspection sip disable
We're using FMC, but you got me on the right track. Here is how to configure through GUI:
https://wrmem.net/index.php/2020/05/08/disable-sip-inspection-on-firepower-through-flexconfig/
It works either way, but with command line is much faster and straightforward 🙂
