Problem with ssh connection to PIX 515 E 7.0 (4)
dian.it
I configure x.x.x.x address to access trougth ssh at PIX in external interface, when i try to connect, ssh client prompt me: "Server Unexpectedly Closed Network Connection". I test from so many carriers at result its the same.
Whats can be the problem ?
smahbub
Level 6
Level 6
you manually change the $DISPLAY environment variable in an SSH environment, the easiest recovery method is to log off and reestablish the SSH connection.
Step 2 To set the DISPLAY environment variable, do the following:
a. For the K or Bourne shell:
export DISPLAY=:0.0
b. For the C-shell:
setenv DISPLAY=:0.0
pgalligan
What SSH client are you using, and on what OS?
