Problem with traffic through IPSec site-to-site tunnel
ABaker94985
Traffic was flowing through this tunnel but recently stopped. When doing a packet-trace on the outside interface using a valid IP from our customer, the following results, and I can't figure out why Phase: 6 denies the flow. Any thoughts? This tunnel is up, and I see bidirectional traffic on phase 2. Thank you.
packet-tracer input outside tcp ##.138.220.70 2000 #.223.248.13 21 det
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (inside,outside) source static obj-172.16.11.10 obj-#.223.248.13 destination static CUSTOMER-VPN CUSTOMER-VPN
Additional Information:
NAT divert to egress interface inside
Untranslate #.223.248.13/21 to 172.16.11.10/21
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group OUTSIDE in interface outside
access-list OUTSIDE extended permit ip object-group CUSTOMER-VPN host 172.16.11.10
access-list OUTSIDE remark Permit restricted ICMP traffic
object-group network CUSTOMER-VPN
network-object 192.168.2.0 255.255.255.0
network-object host 192.168.107.24
Forward Flow based lookup yields rule:
in id=0x78394aa8, priority=13, domain=permit, deny=false
hits=3, user_data=0x70f79d00, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
src ip/id=##.138.220.70, mask=255.255.255.255, port=0, tag=0
dst ip/id=172.16.11.10, mask=255.255.255.255, port=0, tag=0, dscp=0x0
input_ifc=outside, output_ifc=any
Phase: 3
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate ##.138.220.70/2000 to ##.138.220.70/2000
in id=0x774a6fb8, priority=6, domain=nat, deny=false
hits=65, user_data=0x75c87438, cs_id=0x0, flags=0x0, protocol=0
dst ip/id=#.223.248.13, mask=255.255.255.255, port=0, tag=0, dscp=0x0
input_ifc=outside, output_ifc=inside
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
in id=0x757732a8, priority=1, domain=nat-per-session, deny=true
hits=5344794649, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
input_ifc=any, output_ifc=any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0x7582a7d0, priority=0, domain=inspect-ip-options, deny=true
hits=4256517931, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: VPN
Subtype: ipsec-tunnel-flow
Result: DROP
Config:
in id=0x79902f80, priority=70, domain=ipsec-tunnel-flow, deny=false
hits=699, user_data=0x27e77104, cs_id=0x7da6de88, reverse, flags=0x0, protocol=0
dst ip/id=#.223.248.0, mask=255.255.255.128, port=0, tag=0, dscp=0x0
Result:
input-interface: OUTSIDE
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ASA5520-A(config)#
Inside have by default permit any any
but if you config any ACL on inside interface then this ACL will end with deny any any
so please change the ACL with add permit traffic through the tunnel.
Thanks for the response, but there is an ACL on the inside, which ends with "permit ip any any." I figured out the source of the problem, but I'm not sure why the configuration is incorrect. I did a packet-trace (packet-tracer input outside tcp ##.138.220.70 2000 172.16.11.10 21 det) where I  accidentally changed the destination from the public address to the private address, and the packet-trace finished successfully . I need to figure out why NATing isn't working.
I might add that when I do the packet-trace from the inside to the remote end of the VPN tunnel, there is a phase where 172.16.11.10 is translater to #.223.248.13.
