Problem with VPN monitor (Site-to-Site VPN using IPSec )
abhi_murali
I am doing a project in Site-to-site VPN using IPSec and monitoring and managing the network using cisco works(VPN/Security Managament solutions V2.0).
My network is working fine...i can ping from both sides and the "show commands" shows that the packets are encrypting and decrypting.but the Cisco VPN monitor dash board is not showing any active tunnels. Instead its showing N/S( the device is not supported).
I am using 2600 routers for VPN setup and simulating ISP with frame-relay setup.
I am really stuck with the problem. anybody please help me.
I am attaching my network diagram, router configurations and snapshots from VPN monitor as a zip file.
regards
Abhi
a-vazquez
Level 6
Level 6
Known problems are unexpected behaviors or defects in VPN Monitor software releases. They are graded according to severity level.
These release notes contain descriptions of:
All severity level 1 or 2 bugs.
Significant severity level 3 bugs.
All customer-found bugs (regardless of severity level).
http://www.cisco.com/en/US/products/sw/cscowork/ps2326/prod_release_note09186a00800ad91c.html#64643
