Problems after upgrading to 7.0 on Cisco Firepower 2110 standalone
steinbasma
Hi all!
After upgrading from 6.4.0 to 7.0.0 I am stuck with some pending deployment changes. When I try to deploy them I get the following error:
  • ERROR: Failed to open "udp/localized/25/4500"
    ERROR: Error opening IKE port 4500 on Interface outside
    Config Error -- crypto ikev1 enable outside
I have seen som other have similar error on an ASA based device, but this is FTD/FDM based. Any clues anyone?
Chakshu Piplani
The above error happens when you try to enable ikev1 (udp 4500) but there is a connection on your FTD (pass through) with that port being used.
In order to fix it, we need to clear the connection and proceed with the deploy again.
Try following the workaround in this defect: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf82733
Chakshu
Do rate helpful posts!
Chakshu Piplani
Chakshu
Hello Chakshu!
Thanks for the workaround pointer. That did the trick
