Problems with deployement MC IPS 2.2 into 7206
futyncndj
Dear All!
When I'm trying to deploy a configuration prepared in Cisco VMS 2.3 for a 7206 router with IPS, the configuration does install on the router, and starts working.
However, the deployment procedure ends with the following error: "Unable to process SensorConfigDeploy - Error while converting time from String to Long format".
Could you plese advice us how to work around this error, if possible? Thank you!
Maxim
fmeetz
Level 4
Level 4
Try again by reinstaling the cisco VMS 2.3 on the 7206 router
