Problems with NTP and set clock ASA 5585
RAUL1784
Hi all,
We have problems to change hour my device. We try put command npt in conf t but it´s not permited. And command clock also isn´t permited.
Device is ASA5585-SSP-10 and him version is Software Version 9.6(3)9.
This ASA have two contexts but in both contexts we have same problem.
ciscoasa(config)# ntp
ERROR: % Invalid input detected at '^' marker.
ciscoasa(config)# ntp?
ERROR: % Unrecognized command
ciscoasa# clock ?
ciscoasa# clock
thanks so much in advance,
BR
esenuniez1
Hi Raul!
I hope you´re doing well.
You must to change the context to "System context", and in this context, you can configure NTP and set clock.
Tell me if you have any problem.
Regards!
