Problems with PDM PIX ( 506 6.3.(5) )
ramesys12
Whenever we try to make changes from the PDM it doe snot save changes and simply says that it has taken more than 60 seconds and pelase try again. The connection never drops to the firewall not sure what is wrong here.
Can somone pelase guide us with this problem.
Hardware: PIX-506E, 32 MB RAM, CPU Pentium II 300 MHz
Flash E28F640J3 @ 0x300, 8MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 0016.46c6.cd96, irq 10
1: ethernet1: address is 0016.46c6.cd98, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces: 2
Maximum Interfaces: 4
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Serial Number: 81234567895 (0x3333f95e1)
Running Activation Key: 123
Configuration has not been modified since last system restart.
JLFW01# sh flash
flash file system: version:3 magic:0x12345679
file 0: origin: 0 length:1978424
file 1: origin: 2097152 length:5049
file 2: origin: 0 length:0
file 3: origin: 2228224 length:3152452
file 4: origin: 0 length:0
file 5: origin: 8257536 length:308
Upgraded the PDM version to 304
JLFW01# copy tftp flash:pdm
Address or name of remote host [0.0.0.0]? 10.10.10.2
Source file name [cdisk]? pdm-304.bin
copying tftp://SBS-dc/pdm-304.bin to flash:pdm
[yes|no|again]? yes
Erasing current PDM file
Writing new PDM file
PDM file installed.
JLFW01# sh flash
JLFW01#
ramesys12
Just to add further to this post the message we get is
"PDM did not get a response from the server in the last 60 seconds. Please check to see that the network connections are still up and try to reconnect by refreshing PDM"
Which version of java are you running?
