Problems with RDC after installing a PIX
ruiacrosa
I Have a remote server (with W2000 Server with a PIX 506E) working OK with a VPN Tunnel using IPSEC. This server is used by several telework ers with Remote Desktop Connection (RDC) in Win2000/XP. One of the teleworkers ned more security, so I installed a Cisco PIX 501. Untill this installation everything worked fine, but after the instalation of the PIX 501 it gives an error when I try to connect the RDC. The error is this "The client could not connect to the remote computer. Remote connections might not be enabled or the computer might be too busy to accept new connections. It is also possible that network problems are preventing your connection. Please try your connection again later. If the problem continues to occur, contact your administrator.". Can you help me with this.
jmia
Level 7
Level 7
Rui,
I'm guessing that your 506E hasn't got the apporiate ACLs/static for RDC (port 3389) for your inbound connection from the 501, i.e. you need to allow the public IP (outside interface IP) of your 501 on port 3389 on the 506E.
If I'm wrong on the above then please provide both configurations from the 506E and 501 so that I can check - change any sensitive info if you post the config here.
Hope this helps and let me know.
Jay
Hi, Thanks for the reply. Please, can you send me the command line to allow port 3389 in outside interface? Meanwhile, I let you know the actual configuration of the pix 501:
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx encrypted
passwd xxx encrypted
hostname Fener
domain-name qwerty
clock timezone WEST 0
clock summer-time WEDT recurring last Sun Mar 0:00 last Sun Oct 2:00
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol tftp 69
names
access-list outside_access_in permit tcp any eq 3389 interface outside eq 3389
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute retry 4
ip address inside 192.168.x.x 255.x.x.x
ip audit name AttackPolicy attack action alarm drop
ip audit interface inside AttackPolicy
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.x.x 255.x.x.x inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.x.x-192.168.x.x inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
: end
Thanks for the help.
RR
Rui,
access-list outside_in permit tcp host 213.xx.xx.xx host 211.xx.xx.xx eq 3389
static (inside,outside) tcp 213.xx.xx.xx 3389 10.xx.xx.xx 3389 netmask 255.255.255.255 0 0
access-group outside_in in interface outside
The above config is allowing host 213.xx.xx.xx to connect to port 3389 on my public IP 211.xx.xx.xx,
The static is tarnslating host 213.xx.xx.xx port 3389 to my inside server IP 10.xx.xx.xx on port 3389.
The access-group statement is binding the access-list outside_in to the outside interface.
The reason I have a host-to-host setup for RDC on 3389 is so that only that host (213.xx.xx.xx) can connect to my internal server on port 3389. I could have used 'any host' but this would have allowed any one to connect to my internal server on port 3389 (Not a good idea!)
If you don't have any free public IPs avaliable then you can use keyword 'interface' on your static, i.e.
access-list outside_in permit tcp host 213.xx.xx.xx host eq 3389
static (inside,outside) tcp interface 3389 10.xx.xx.xx 3389 netmask 255.255.255.255 0 0
That keyword interface will correspond to your pix's outside interface IP address therefore, your ACL for the outside interface will need to point to the outside interface IP of your pix, i.e.
access-list outside_in permit host 213.xx.xx.xx host eq 3389
Make sure to issue clear xlate after the modification of the above and save with write mem.
Hope this explains and helps, let me know how you get on or require further help.
Jay
First of all let me thank you for the help you are giving me.
I have tried to use the suggestions you gave me but it didn't work. I have several questions/doubts:
1 - access-list outside_in permit tcp host 213.xx.xx.xx host 211.xx.xx.xx eq 3389 - here when you put 211.xx.xx.xx is my public ip. It happends that my public ip is not static. Where is 211.xx.xx.xx should I put "any". That's what I have tried: access-list outside_in permit tcp host 213.xx.xx.xx host any eq 3389
2 - static (inside,outside) tcp 213.xx.xx.xx 3389 10.xx.xx.xx 3389 netmask 255.255.255.255 0 0
When you put 10.xx.xx.xx is my inside server? Pix Ip or my machine IP? What happens when I have more than 1 pc to acces outside?
Thanks.
RR
