03-16-2011 10:11 AM - edited 03-10-2019 05:18 AM
Have a NME-IPS installed on a 3925.
If I connect my PC to the Management Port on the NME-IPS module I can
access the IDM IP 10.119.117.9
interface IDS-Sensor2/0
ip address 10.119.117.9 255.255.255.252
service-module fail-open
hold-queue 60 out
end
But, I cannot open IDM remotely.
An HTTPS connection to 10.119.117.9 from the network opens CPC on the router itself (not IDM).
Please let me know what I'm missing to be able to administer the module remotely.
Note:
I can log in the sensor via an SSH connection to the router and entering the sensor:
service-module ids-sensor 2/0 status
There's no cable attached to the management-port on the sensor.
I'm trying to open IDM via the backplane connection to the router (using 10.119.117.9), or
do I need the management-port and if so, can the IP be on the same subnet?
Federico.
03-16-2011 10:45 AM
Fede,
I am almost sure that the management should be connected similar to the AIP-SSM on the ASA. Usually the IP of the module is configured on the same subnet but I don't think that is mandatory.
Connect a cable to the management IP and test it out.
03-16-2011 10:52 AM
Paul,
Thank you for jumping in :-)
I did this test:
Connect the management-port to my PC. In this way I can access the sensor via IDM using 10.119.117.9
Even if the management-port is connected to the switch (on the same VLAN), I cannot access the sensor
using IDM remotely from the LAN via 10.119.117.9 (can PING it but the response comes from interface
ids/sensor 2/0 on the router)..
I guess my question is...
If I want to access NME via IDM remotely, which IP should I use?
If I try to access it via 10.119.117.9 remotely I access the router itself.
Federico.
03-16-2011 10:56 AM
Fede,
Check the subnet mask of the management port. You only have two available IPs. I suppose one IP is for the router and the other for the IPS, if your PC on the same subnet?
You should access the IDM using the management IP of the sensor.
03-16-2011 11:06 AM
Yes,
I did this:
ip address 10.119.117.9 255.255.255.0
hold-queue 60 out
end
Then, try to open IDM from a computer on another subnet with access (10.3.1.1)
I can still PING 10.119.117.9 from 10.3.1.1
But if i do https://10.119.117.9 from 10.3.1.1 what I get is CPP (GUI interface for the router itself)
I was hoping to get IDM when doing https://10.119.117.9
If I connect my PC directly to the management port (assign my PC 10.119.117.x), then IDM works.
This is from the sensor:
service host
network-settings
host-ip 10.119.117.9/24,10.119.117.1
I think i understand now...
Question:
The default gateway is the router (Loopback interface)
interface Loopback1
ip address 10.119.117.1 255.255.255.255
This is why all traffic is send back to the backplane to the loopack....
If the only way to open IDM remotely via the management-port, how do I assign an IP to the management-port and it's gateway correctly???
Federico.
03-16-2011 11:23 AM
Fede,
Can you run again the setup command on the IPS and use a different IP on the same subnet of the LAN interface of the Router?
The interface IDS-Sensor2/0 is basically the interface used for the router to connect to the IPS. When you use the command "service-module ids-sensor 2/0 session" it makes a reverse telnet to what ip? I guess it is 10.119.117.9, right?
Change the ip of the sensor and test again. Remember to allow the remote subnet on the ACL of the IPS so that you can connect to it.
If possible please include the show config of the sensor.
03-16-2011 12:47 PM
Paul,
I see what you're saying.. thanks I will give it a try and let you know.
Federico.
03-17-2011 08:13 PM
Ok.
When the NME-IPS has the following information:
IP 10.119.117.10/30
GW 10.119.117.9
Router ids-sensor interface 10.119.117.9/30
There's no way to access the sensor remotely.
Cannot even PING between 10.119.117.9 and 10.119.117.10
Now...
If I configure the sensor with an IP from the LAN and GW LAN interface of the router, I can access IDM from anywhere.
The problem here is the client follow an standard where all other facilites have the above configuration.
So my question is..
Is it possible to manage the NME-IPS remotely via the backplane connection to the router?
If not... where do I connect the management port to? (since there's no separate IP for the management port).
Federico.
03-21-2011 05:42 PM
You can actually manage the module from the backplane using this command in your router service-module idS-Sensor 0/0 session
About the remote management just try to check the access-list in the module.
Please post the following output
IPS-# conf ter
IPS-(config)# ser host
IPS-(config-hos)# network-settings
IPS-(config-hos-net)# sh sett
If you want to allow a host to manage your IPS it has to be listed in the ACL. To add a host just change the ACL
IPS-(config-hos-net)# access-list
