Replacing PIX with 2811 - https problems
jcowtan
Level 3
Level 3
I had set up an interim pix that supported an AS/400 HTTPS applcaition to a remote site. No changed were made to the PIX other and setting up PPPoE. It worked from the start!!!
How we are replacing the PIX with a 2811 running 12.3(8)T8. I have attached the conifuration. The AS/400 can no longer access the remote site and its application. What am I missing on the 2811 to support HTTPS like the PIX did?
a.alekseev
Level 11
Level 11
You need open a case in the cisco tac.
I'm sure that it's a BUG in inspection engine.
Found the problem. It was in the server application. We were changing the default route to this test 2811, but the route did not apply. We now have it working.
