Routing Problems across Quad Ethernet Cards in Pix 515e
tulletts
I'm having trouble routing between Quad Ethernet Cards on the same PIX and between ports on the same Quad Card. However, each Quad Card can commnicate via the Pix's own ethernet interface.
I'm using a PIX 515e running s/w 6.2.3
Does anyone have any suggestions ?
scoclayton
Level 7
Level 7
This should work fine...we would need to take a look at the config to assist.
Scott
