runts error on a trunk port between pix and catalyst
efluxa
I'm reporting a lot of input errors and runts errors
on switch port (catalyst 3548xl ios ver 12.0(5.3)WC1 ) in trunk with a pix515 (ver. 6.3(4))
There's no auto-negotation problem, I've tried to fix "100full" and "auto" on both ports but the errors on the catalyst continue to increase.
Interfaces on pix:
interface ethernet0 100full
interface ethernet1 auto
interface ethernet1 vlan5 logical
interface ethernet1 vlan6 logical
nameif vlan5 dmz_public_server security50
nameif vlan6 fw-to-ir security80
on the catalyst:
interface FastEthernet0/4
description "trunk dot1q to pix"
switchport mode trunk
spanning-tree portfast
no cdp enable
Here the errors on the switch port:
5 minute input rate 124000 bits/sec, 9 packets/sec
5 minute output rate 24000 bits/sec, 38 packets/sec
43037 packets input, 44948989 bytes
Received 0 broadcasts, 4009 runts, 0 giants, 0 throttles
4009 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast
Also I've tried to allow only the two vlans on the switch interface, but nothing is changed.
Thanks in advance
Luca
Patrick Iseli
Level 7
Level 7
RUNT errors
Take a look this link, I have no idea if that is the problem but could be a good point to start troubleshooting the problem.
http://support.intel.com/support/express/switches/sb/CS-014410.htm
RUNT:
A runt is an undersized packet (less than 64 bytes) with a valid CRC. Packets less than 64 bytes with an invalid CRC are counted as fragments.
sincerely
Patrick
