SCEP on PIX using not port 80
berndtonn
for security reasons we are using a non-standard port for accessing our CA using SCEP. On routers and VPN clients this is no problem, but obviously the PIX does not support that.
Is there any way to configure a PIX to change the port number itself before it sends out the request ("port redirection" for outgoing, self-initiated connections) ?
Any hints would be appreciated.
Bernd
bbaley
Level 3
Level 3
Did you ever find a solution for this? I'm having a similar problem.
TIA
kdurrett
Level 3
Level 3
Sorry, this isnt possible on the pix. As you say, you can change on the router but you arent going to be able to accomplish this on the pix.
