Secondary ASA interface Flap when issue write Standby
ahmad82pkn
Level 7
Level 7
i never see this before, but on newly purchased just configured firewall.
when i do wrtie standby.
All interfaces on standby unit flaps.
is it some IOS bug? my firewalls are
Hardware:   ASA5525, 8192 MB RAM, CPU Lynnfield 2394 MHz, 1 CPU (4 cores)
                   ASA: 4096 MB RAM, 1 CPU (1 core)
and image
asa861-2-smp-k8.bin
what could be the reason? FYI i am using lan base failover and not doing any statful failover.
Sanjay Shaw
Level 4
Level 4
Hi Ahmad,
This is expected behavior and when we issue the command "write standby", we see the device configuration getting erased and then re-configured from the active device. Device goes in the Sync config and Bulk Sync state in transition. Here is more info regarding the same :
write standby
. This is a misleading message and a cosmetic issue is filed with this defect id :
CSCuc63634  This is expected behavior and when we issue the command "write standby", we see the device configuration getting erased and then re-configured from the active device. Device goes in the Sync config and Bulk Sync state in transition. Here is more info regarding the same : write standby. This is a misleading message and a cosmetic issue is filed with this defect id : CSCuc63634
Due to the configuration being removed and re-applied we saw the link flap on the standby devices.
Please rate this if helpful.
Eddy Duran
Level 4
Level 4
Hello Ahmad,
Are you monitoring both units using syslogs?
Do you get any message or syslog when the issue happens?
- Eddy
Sanjay Shaw
Level 4
Level 4
Hi Ahmad,
write standby
thank you for the information, though this behavior would be new for me, since i never saw this on my dozen pair which are in production, May be something with new generation ASA series.
