Serial port, ethernet management and default ethernet management
lorenzonerimail
Hello to everybody,
I'm trying to install properly the DC200. I'm trying to connect in the serial console port, but with some problems...
Please, see the image in attachment:
1) Which is the difference between ports 6 and 7? Both are management interfaces...
2) And then, which is the correct way to configure the initial steps? The Cisco Guide is not very clear for me... First of all can I connect to Serial port or before I have to connect to VGA with a monitor and a keyboard for redirect the output to the serial port?
Does this mean that I have to run sudo /usr/local/sf/bin/configure_console.sh serial and then sudo reboot for to work properly the serial console port?
3) Then, from which interface I'll can take the managed devices?
Thank you in advance
Lor
Ed Padilla Jr
If you are trying to console in, just a Monitor for the VGA connector, and a USB keyboard will suffice.
Ed Padilla Jr
