simple ?? interface problem
dufour001
Level 2
Level 2
Hello, I'm currently configuring an ASA5510.
I connected a laptop (IP 192.168.96.18/255.255.255.0) to port 0/2 and tried to ping 192.168.100.2 ... impossible to ping outside interface ...
I resetted the config of the ASA to retest more simple.
Here my config.
What is missing ?
Thx
ASA Version 7.0(8)
hostname ciscoasa
names
dns-guard
interface Ethernet0/0
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/1
nameif OUTSIDE
security-level 100
ip address 192.168.100.2 255.255.255.0
interface Ethernet0/2
nameif INSIDE
security-level 100
ip address 192.168.96.17 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list OUTSIDE_access_in extended permit ip any any
access-list OUTSIDE_access_in extended permit icmp any any
access-list INSIDE_access_out extended permit ip any any
access-list INSIDE_access_out extended permit icmp any any
access-list OUTSIDE_access_out extended permit ip any any
access-list OUTSIDE_access_out extended permit icmp any any
access-list INSIDE_access_in extended permit ip any any
access-list INSIDE_access_in extended permit icmp any any
pager lines 24
logging asdm informational
mtu management 1500
mtu OUTSIDE 1500
mtu INSIDE 1500
no asdm history enable
arp timeout 14400
access-group OUTSIDE_access_in in interface OUTSIDE
access-group OUTSIDE_access_out out interface OUTSIDE
access-group INSIDE_access_in in interface INSIDE
access-group INSIDE_access_out out interface INSIDE
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
: end
varrao
Level 11
Level 11
this is the default behavior of ASA, you would never be able to ping a remote interface on the ASA, you can only ping interface inside friom the ASA. This is a security feature which restricts it on the ASA. Remote interfaces do not ping and cannot be used for management access, only the interface which is connected to the host.
Hope this helps.
Varun
Varun Rao
