Simple Port Forwarding / ACL Question
macdady843
Hi Everyone,
I'm kind of a novice when it comes to Cisco configuration. I went to college for networking but haven't used it enough since graduating and I'm having some trouble with opening some ports for email to my home PC.
Specifically i'm trying to set up IMAP with Gmail to be downloaded to my Mozilla Thunderbird client. I'm using a similar syntax for other ports that i've opened but it isn't working. I also did a "show access list" and saw that one of my rules had hit counts on it but i'm not sure what this means as far as troubleshooting goes.
Can someone lend a hand and explain what i'm doing wrong? If you're feeling extra nice could you let me know what I would need to do to open some Xbox Live ports as well? The rules aren't set up yet but the ports are present in my config. I've bolded the relevant ports below.
*** Config ****
ASA Version 8.2(5)
hostname RyansFirewall
enable password C5OQraC02mISnP8p encrypted
passwd 3mBdM08UO1apR0bB encrypted
names
name 192.168.1.130 theking
name 192.168.1.240 wap
name 192.168.1.252 cam
name 192.168.1.253 switch
name 192.168.1.150 xbox
name x.x.x.x vpnreactor
name x.x.x.x HSoftware
name x.x.x.x Mom_and_Dad
interface Ethernet0/0
description Connection_to_Cable_Modem
switchport access vlan 10
interface Ethernet0/1
description Cisco_Catalyst_2960
interface Ethernet0/2
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
description Guest_Wireless
switchport access vlan 20
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
interface Vlan1
description Private_Internal_Lan
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Vlan10
description WOW_Internet
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan20
no forward interface Vlan1
nameif dmz
security-level 30
ip address 172.16.1.254 255.255.255.0
boot system disk0:/asa825-k8.bin
ftp mode passive
clock timezone Eastern -5
object-group network outside_ip_group
description This group contains a list of allowed public IP Addresses
network-object HSoftware 255.255.255.255
network-object Mom_and_Dad 255.255.255.255
object-group service Xbox_Ports tcp-udp
description Ports needed for Xbox Live
port-object eq www
port-object eq 88
port-object eq domain
port-object eq 3074
object-group service Email_Ports tcp-udp
description Ports needed for Email
port-object eq 143
port-object eq 465
port-object eq 587
port-object eq 993
access-list outside_access_in extended permit tcp object-group outside_ip_group any eq 1024
access-list outside_access_in extended permit tcp any any eq 3389
access-list outside_access_in extended permit tcp any any eq ftp
access-list outside_access_in extended permit gre host vpnreactor host theking
access-list outside_access_in extended permit tcp host vpnreactor host theking eq pptp
access-list outside_access_in extended permit icmp any any echo-reply
access-list outside_access_in extended permit icmp any any time-exceeded
access-list outside_access_in extended permit icmp any any unreachable
access-list outside_access_in extended permit tcp object-group outside_ip_group any eq 5900
access-list outside_access_in extended permit tcp any any object-group Email_Ports
access-list outside_access_in extended permit udp any any object-group Email_Ports
pager lines 24
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-635.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (outside) 1 access-list outside_access_in
nat (dmz) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 3389 theking 3389 netmask 255.255.255.255
static (inside,outside) tcp interface ftp theking ftp netmask 255.255.255.255
static (inside,outside) tcp interface 1024 cam 1024 netmask 255.255.255.255
static (inside,outside) tcp interface 5900 theking 5900 netmask 255.255.255.255
static (inside,outside) tcp interface 143 theking 143 netmask 255.255.255.255
static (inside,outside) tcp interface 465 theking 465 netmask 255.255.255.255
static (inside,outside) tcp interface 587 theking 587 netmask 255.255.255.255
static (inside,outside) tcp interface 993 theking 993 netmask 255.255.255.255
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh Mom_and_Dad 255.255.255.255 outside
ssh HSoftware 255.255.255.255 outside
ssh timeout 10
console timeout 10
dhcpd address 192.168.1.2-192.168.1.25 inside
dhcpd dns x.x.x.x x.x.x.x interface inside
dhcpd lease 10800 interface inside
dhcpd domain RyanJohn interface inside
dhcpd enable inside
dhcpd address 172.16.1.2-172.16.1.25 dmz
dhcpd dns 8.8.8.8 8.8.4.4 interface dmz
dhcpd domain RyanJohnGuest interface dmz
dhcpd enable dmz
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username XXXXX password ZpRIy72StEDDpdfG encrypted
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect pptp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:3c7abf7d5d55aba0e19d5da340132000
: end
*** Show Access List ****
RyansFirewall# show access-list outside_access_in
access-list outside_access_in; 19 elements; name hash: 0x6892a938
access-list outside_access_in line 1 extended permit tcp object-group outside_ip_group any eq 1024 0xf13a69fb
  access-list outside_access_in line 1 extended permit tcp host HSoftware any eq 1024 (hitcnt=0) 0xc8c42900
  access-list outside_access_in line 1 extended permit tcp host Mom_and_Dad any eq 1024 (hitcnt=0) 0x7e777675
access-list outside_access_in line 2 extended permit tcp any any eq 3389 (hitcnt=7451) 0x51a647d7
access-list outside_access_in line 3 extended permit tcp any any eq ftp (hitcnt=11) 0x8d0d5aac
access-list outside_access_in line 4 extended permit gre host vpnreactor host theking (hitcnt=0) 0x894a4bbb
access-list outside_access_in line 5 extended permit tcp host vpnreactor host theking eq pptp (hitcnt=0) 0xcb0322a8
access-list outside_access_in line 6 extended permit icmp any any echo-reply (hitcnt=563) 0x54b872f3
access-list outside_access_in line 7 extended permit icmp any any time-exceeded (hitcnt=703) 0x03690eb3
access-list outside_access_in line 8 extended permit icmp any any unreachable (hitcnt=7408) 0x5c2fa603
access-list outside_access_in line 9 extended permit tcp object-group outside_ip_group any eq 5900 0xe88875b2
  access-list outside_access_in line 9 extended permit tcp host HSoftware any eq 5900 (hitcnt=0) 0x2208e16f
  access-list outside_access_in line 9 extended permit tcp host Mom_and_Dad any eq 5900 (hitcnt=0) 0xa3aaaedd
access-list outside_access_in line 10 extended permit tcp any any object-group Email_Ports 0x91529965
  access-list outside_access_in line 10 extended permit tcp any any eq imap4 (hitcnt=17) 0x53d153bd
  access-list outside_access_in line 10 extended permit tcp any any eq 465 (hitcnt=0) 0x4d992f5e
  access-list outside_access_in line 10 extended permit tcp any any eq 587 (hitcnt=0) 0x734d200d
  access-list outside_access_in line 10 extended permit tcp any any eq 993 (hitcnt=0) 0xb91930a9
access-list outside_access_in line 11 extended permit udp any any object-group Email_Ports 0xe12dbb9d
  access-list outside_access_in line 11 extended permit udp any any eq 143 (hitcnt=0) 0x34d1c49d
  access-list outside_access_in line 11 extended permit udp any any eq 465 (hitcnt=0) 0x5cc4b908
  access-list outside_access_in line 11 extended permit udp any any eq 587 (hitcnt=0) 0x6e3b53a3
  access-list outside_access_in line 11 extended permit udp any any eq 993 (hitcnt=0) 0x7f9dd9b7
20 Replies 20
I wouldn’t trust certain regions in the world; I would at least use different ports. You could keep them the same on the inside, but on the outside you wouldn’t be connecting to 3389.  Ideally you would use different ports (unless you can’t) but also create a list of subnets that can use that service and deny the rest.
From the capture, we did see traffic.  Was that traffic from the telnet command?  Try the packet tracer command again but instead of 192.168.1.10 use the machine you are trying to get the e-mail client to work on.
Yes the capture was from the telnet command. I re-ran the packet tracer to my machine IP address and got the same success result.
What OS are you using?  Is a software firewall being used on the local machine?
I'm using Windows XP and I do have a Zone Alarm software firewall but i've disabled it for purposes of this testing.
If the firewall is dropping the traffic for any reason, then this will show us:
cap IMAP type asp-drop all real-time
Perform your IMAP test with your mail client and post the results.
So I went ahead and set up the ASDM console which I hadn't used before and somehow got it working. Not really sure what changed except for the fact that there is a command called "nat-control" now present. I pasted the new config below if you'd like to compare. Thanks for the help.
ASA Version 8.2(5)
names
name 76.73.18.130 vpnreactor
shutdown
shutdown
shutdown
shutdown
interface Vlan1
nameif inside
security-level 100
interface Vlan10
nameif outside
security-level 0
interface Vlan20
nameif dmz
security-level 30
ftp mode passive
same-security-traffic permit intra-interface
network-object HylandSoftware 255.255.255.255
service-object tcp-udp eq 3074
service-object tcp-udp eq domain
service-object tcp eq www
service-object udp eq 88
service-object tcp eq 465
service-object tcp eq 587
service-object tcp eq 933
service-object tcp eq imap4
access-list outside_access_in extended permit tcp any host theking eq 4444
access-list outside_access_in extended permit object-group Xbox_Ports any host xbox
pager lines 24
mtu inside 1500
mtu outside 1500
mtu dmz 1500
arp timeout 14400
nat-control
nat (outside) 1 access-list outside_access_in dns
static (inside,outside) tcp interface 4444 theking 3389 netmask 255.255.255.255
http server enable
telnet timeout 5
ssh HylandSoftware 255.255.255.255 outside
ssh timeout 10
console timeout 10
dhcpd dns 64.233.214.34 64.233.214.41 interface inside
dhcpd enable inside
dhcpd enable dmz
webvpn
username rfosco password ZpRIy72StEDDpdfG encrypted
  inspect pptp
Cryptochecksum:07d54f18cd4da365f9afc97d5c4ffb12
: end
