Solution: unable to reserve port 443 for static PAT
milkboy33
This problem applies (in my case) to our ASA5510. The issue here is that the http service on the ASA is runnnig off of the standard port 80. Login to the firewall and run the following.
no http server enable
http server enable 8080
Now you should be able to add a NAT/PAT on port 443 to another server of your liking. Just remember when you attempt to use ASDM to manage the ASA in the future to specify the new port 8080.
mirober2
Thanks for sharing your solution with the community! I'm sure this will help others in the future.
-Mike
