Some Problems using Cisco Configuration Professional For 891 Router
softimpera
For the moment we have a router Lynksys RV042 , and we want to change it with an Router Cisco 891 .
I have configured our new router Cisco 891 using Cisco configuration Professional because I am not an cisco expert:
I have configured : DHCP, DNS, NAT, Firewall (I have selected : Advanced , Low Security) . (Please look in the attachments) .
I have tested the new router and :
- Internet is working
- We can send Emails, Receive Emails from Outlook
- Our Web sites cand be accessed from the outside .
- File Share is working
We have 2 problems
1. Can't Access from inside the network : our public ips configured in the NAT :  **.***.**.150 .
When we try : ping **.***.**.150 , we receive : Request Timed Out .
When we try ping 192.168.1.2 , everything it's ok.
When we try ping from outside of the network , everything it's ok.
Can somebody help me ?
PS : I want to mention that : if I put back the old router I can access our public IPs.
2. When I send Emails to yahoo and access View Full Header I receive :  dkim=temperror (key retrieval failed)
Received-SPF: pass (domain of ********.com
designates **.***.**.150 as permitted sender)
Authentication-Results: mta1036.mail.ac4.yahoo.com  from=********.com; domainkeys=pass (ok);  from=********.com; dkim=temperror (key retrieval failed)
Received: from 127.0.0.1  (EHLO mail.********.com ) (**.***.**.150)
  by mta1036.mail.ac4.yahoo.com with SMTP; Sat, 04 Aug 2012 01:48:53 -0700
DomainKey-Signature: a=rsa-sha1; c=simple; q=dns;         d=********..com ; s=applications;
I think our Email Server (Smarter Email) is using the ip Adress: 127.0.0.1 (Please look in the attachement) and this ip is restricted from the firewall (ccp in zone to out zone : Drop :  127.0.0.0/0.255.255.255) (generated by Advanced firewall > Low Security) .
How can I set that to work ? Can I delete that row ?
Thank's
7 Replies 7
Hi Bro
Why do you need to PING the Static NAT Public IP from the LAN? Can you put a simple network diagram here, so that everyone else can assist you? and state what are you trying to achieve.
If Linksys can do this, so can Cisco :-)
Warm regards,
Ramraj Sivagnanam Sivajanam
No a 891 router can't do NAT hairpinning so it won't work, there are some workarounds like using FQDN or using NAT on a stick( but I've never configured this one and I heard it can be more trouble than what it tries to solve).
Regards.
Alain
softimpera
I need this because in the web site configurations for example for the database connection is an public ip (This help remote users and local users to work on the same source code) .
But We can live without this for the moment .
Hi Bro
You could refer to this URL for further details http://blog.instruosolutions.com/2012/01/07/dns-doctoring-technique-on-cisco-routers/
Warm regards,
Thank's for the answer .
Now I have another problems:
After configuration : NAT, IP, DHCP, IPS, Firewall, in the production enviroment The 891 Router works very slow .
1.  (Example 1 Test Download ) When I try to download 1 file from the  internet (~100 Mb) : for the  moment it shows the download rate : 2 Mb/s  , then 1Mb/s , then 600 Kb/s  and then stops the download. It is  possible ?
2.  (Example 1 Test Upload) Then I have uploaded a file.zip on our server  (**.***.**.150)  (~ 30 Mb) in the public wwwroot . Then I  try to  download this file from another place over internet and it's the same  problem  .
3. There are no problems Inside the network for the transfer (120 Mbs) .  (there is an Switch Cisco Gigabit )
If I put back the RV042 , everything it's ok the download is : ~ 2 Mb/s and in 1-2 minute the download is finished.
Our internet provider bandwith is up to : 15 Mb/s .
I want to mention that I can access web site like : Google, Yahoo without problems . The problems begins when I try to downlod some files over internet over  3 - 5 Mb .
In  the middle of the day the bandwith we need is ~ 7 Mb/s updload (there  are web servers Email, DSN, Web) and maximm 1 Mb /sec Download .
I looked in the Cisco Configuration Professional and: the Bandwith is : 3 - 5 % , Processor: 30 - 40 %, Memory : 40 - 50 % .
Any Ideas ?
I made more tests and I want to ask : is there an IPS rule that fragment the download ? because : when I hit again retry download : the download starts , then the browser download 5 - 10 Mb and then stops .
Seems like the trafic is fragmented in pieces of maximum 10 mb for example .
It's very strange .
Here is my configuration
Building configuration...
Current configuration : 11684 bytes
! Last configuration change at 15:49:55 PCTime Fri Aug 17 2012 by admin
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname hsdf3ra
boot-start-marker
boot system flash:/c890-universalk9-mz.152-4.M1.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $3$gadds3asdfasdfa435345dfg1OGtVM060DY/
no aaa new-model
clock timezone PCTime -8 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-41548103
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-41548103
revocation-check none
rsakeypair TP-self-signed-41548103
crypto pki certificate chain TP-self-signed-41548103
certificate self-signed 01
  3082024C 308201B5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  2F312D30 2B060355 04031324 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 E4F34959 34313534 1D130101 301E170D 31323038 30373136 33373332
  5A170D32 30303130 31303030 3030305A 302F312D 302B0603 55040313 24494F53
  2D53656C E4F34959 676E6564 2D436572 74696669 63617465 2D343135 34383130
  3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100DB8B
  4231D71B C54A58A7 65481793 E2D38810 7AAD2221 12B350FA A5E65185 7697598E
  15A8D708 13D27B05 A0030201 8F92C8FD 72ED6F3E 6AA12B6A 0D287F40 29A32CA2
  006242C4 D118C7FB 8DE4703D 97F8A28D 1AE85FF1 2C5571DD 3F3904E2 95501C43
  DAA5214A 84A74DD7 1507E056 AD68EA40 DB8FA15B 89B8EF72 584689D9 83350203
  010001A3 78307630 0F060355 1D130101 FF040530 030101FF 30230603 551D1104
  1C301A82 18686F73 74696D70 6572612E 686F7374 696D7065 72612E72 6F301F06
  03551D23 04183016 80142ADF 5DC3F92C 4793A0EB 00678B7A 18D5EE6E 6A13301D
  0603551D 0E041604 142ADF5D C3F92C47 93A0EB00 678B7A18 D5EE6E6A 13300D06
  092A8648 86F70D01 01040500 03818100 27BD56DD 58244337 5C1E329D 3DFE4196
  DB9382DE D257ED68 C54951C0 03743736 E4F34959 3B362BCC E1460A85 EE084720
  BE5E284E 32E50561 7DE44D6E 8F199843 3082024C 1CF7DCF8 D283881E EDCF839A
  2F1E65ED F68AE6B2 7CE41DC8 27BD56DD BDB8D9C7 6E5C823E 5C95A143 E4F34959
  5505F994 91FE05B7 50891BE0 F39754A3
      quit
no ip source-route
ip dhcp excluded-address 192.168.1.1
ip dhcp pool ccp-pool1
import all
network 192.168.1.0 255.255.255.0
dns-server xx.xx.xx.1 xx.xx.xx.1
default-router 192.168.1.1
ip dhcp pool work1
host 192.168.1.4 255.255.255.0
client-identifier 0148.ac5f.9708.df
ip dhcp pool s25
host 192.168.1.15 255.255.255.0
client-identifier 01568.7gh4.bgf5.71
ip dhcp pool Hods01
host 192.168.1.2 255.255.255.0
client-identifier 0rt4.a672.8569.3f
ip dhcp pool s2
host 192.168.1.11 255.255.255.0
client-identifier 0560.17c4.a236.e1
no ip bootp server
ip domain name dsfg.com
ip name-server xx.xx.xx.xx
ip ips config location flash:/IPS retries 1
ip ips notify SDEE
ip ips name sdm_ips_rule
ip ips signature-category
  category all
   retired true
  category ios_ips basic
   retired false
ip cef
no ipv6 cef
license udi pid CISCO891-K9 sn F451d12fghSX
username admin privilege 15 secret 5  sdfasdf
username admin2 privilege 15 secret 5  asdsdf
redundancy
crypto key pubkey-chain rsa
named-key realm-cisco.pub
  key-string
   30234122 BFF668E9 2A864886 F70D0101 50437722 82010F00 3082010A 02820101
   00C19E93 A856724A D6CC7A24 1D130101 206BE3A2 06FBA13F 6F12CB5B 4E441F16
   17E630D5 C02AC252 912BE27F 37FDD9C8 11FC7AF7 DCDD81D9 43CDABC3 6007D128
   B199ABCB D34ED0F9 08567DC1 359C189E F30AF10A C0EFB624 7E0764BF 3E53053E
   5B2146A9 D7A5EDE3 0298AF03 DED7A5B8 9479039D 20F30663 9AC64B93 C0112A35
   FE3F0C87 89BCB7BB 994AE74C 08567DC1 1D130101 85EAF974 6D9CC8E3 F0B08B85
   50437722 FFBE85B9 5E4189FF CC567CB9 69C46F9C A84DFBA5 7A0AF99E AD768C36
   006CF498 079F88F8 A3B3FB1F 9FB7B3CB 5539E1D1 9567CCBB 551F78D2 892356AE
   2F56D826 8918EF3C 80CA4F4D 87BFCA3B BFF668E9 689782A5 C657CB6E 1D130101
   F3067501 0001
  quit
ip tcp synwait-time 10
no ip ftp passive
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-all sdm-nat--4
match access-group 104
class-map type inspect match-all sdm-nat--1
match access-group 101
class-map type inspect match-all sdm-nat--2
match access-group 102
class-map type inspect match-all sdm-nat--3
match access-group 103
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-all ccp-cls-ccp-inspect-1
match access-group name N100at
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
match protocol ms-sql
match protocol ms-sql-m
match protocol sqlsrv
match protocol sqlserv
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat--1
  inspect
class type inspect sdm-nat--3
  inspect
class type inspect sdm-nat--2
  inspect
class type inspect sdm-nat--4
  inspect
class class-default
  drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-cls-ccp-inspect-1
  inspect
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
policy-map type inspect ccp-permit
class class-default
  drop
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
description $ES_WAN$$FW_OUTSIDE$
ip address xx.xx.xx.157 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip ips sdm_ips_rule in
ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
interface GigabitEthernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$$ES_LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip forward-protocol nd
ip nat inside source list 1 interface FastEthernet8 overload
ip nat inside source static 192.168.1.11 xx.xx.xx.146
ip nat inside source static 192.168.1.12 xx.xx.xx.147
ip nat inside source static 192.168.1.4 xx.xx.xx.148
ip nat inside source static 192.168.1.2 xx.xx.xx.150
ip route 0.0.0.0 0.0.0.0 FastEthernet8
ip access-list extended N100at
remark CCP_ACL Category=128
permit ip host 127.0.0.1 any
ip access-list extended Nat100
permit ip any host xx.xx.xx.150
permit ip any host xx.xx.xx.148
ip sla auto discovery
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip xx.xx.xx.128 0.0.0.127 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.1.2
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip any host 192.168.1.4
access-list 103 remark CCP_ACL Category=0
access-list 103 permit ip any host 192.168.1.11
access-list 104 remark CCP_ACL Category=0
access-list 104 permit ip any host 192.168.1.12
no cdp run
control-plane
mgcp profile default
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line 1
modem InOut
speed 115200
flowcontrol hardware
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler interval 500
end
