SSH does not work in inside interface in ASA
Chieu Dinh
Level 4
Level 4
I am able to run ASM but I can't run SSH from inside interface. Does anyone know how can I start to debug the problem? I checked all the setting for enable ssh, I setup it the same way as an instruction.
aaa authentication ssh console LOCAL
ssh 192.168.0.0 255.255.255.0 inside
crypto key generate rsa modulus 1024
What I am missing here? I also have username and password for admin.
15 Replies 15
Can you ping the workstation that is trying to ssh into the ASA inside interface from the ASA itself?
Does the ASA routing setup require that traffic to leave via the inside interface?
When you try unsuccessfully to ssh into the ASA does the syslog show any related events?
